Impulse Response Snapshot Control
ECmaj7
Has anyone been able to store different IRs per snapshot?
Not working for me...
This feature was added in firmware 1.3
(UPDATE)
After reseting to factory defaults and adding a few IRs it does work.
As soon as I add many IRs it doesn't work.
Furthermore, other problems arise that I've mentioned before such as scribble strips are blank at boot up.
The work around is go into global setting, fiddle with switches parameters then strips reappear.
But I digress...
At some point either adding a certain number of IRs or maybe creating nested folders cause a problem.
I imagine line 6 is hard at work unraveling code on many fronts.
EC
Check this again after the next update. If not fixed submit a bug report.
