With captures how do I set up and stereo amp signal path?
cragginshred
I plan to do a capture of my Friedman Jose and want to have it in stereo with 2 amps. Can I just copy and paste the amp in the signal path or? Is there a video showing how to do this?
Also in 'Snapshot' mode can I have a clean ish/crunch/solo configuration with 3 captures with the various settings on the amp?
You can only have two proxy clones per path.  I’m not sure why you want stereo amps, but having to split them might put the kibosh on that.
Typically amps are in a mono path and splits after either with cabs or stereo effects.
re: Snapshots… each instance of a proxy is fixed within a Snapshot, meaning you can’t swap different proxy captures in and out. But it’s fine if you are just changing settings using the same proxy capture/block. If you want different proxy captures you will need to have 3 proxy blocks in the preset. DSP might become an issue.
