littlespaceman Posted May 14 Share Posted May 14 As the title says really - coming from the Quad Cortex it’s what I’m used to (no scribble strips on QC either so they use a similar display to the Helix Play view) and I like the Play view on the Stadium as it’s a much nicer screen than the QC. It would be really helpful though if it was possible to bring up the Play view with a footswitch, is this possible? In my scenario the Stadium is on the floor, you’ve bent down to tweak a parameter, stood back up again but forgot to access the Play view before you did - so being able to access it via a f/s would save a lot of bending down and getting back up again Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 14 Share Posted May 14 While in Home -> Edit view press and hold FS6 (the MODE/More switch). Press FS6 again to enter Home -> Play view as specified in your Global Settings Mode 1 and Mode 2 settings, or press any other FS to access the indicated views. Having done this I don't think you can get back to Home -> Edit view without pressing the Home button. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted May 15 Author Share Posted May 15 Perfect, just what I wanted, thank you. Now, the only thing is to request that the Block parameters disappear from view when in the Play view - I really don't need them there, and they take up valuable screen space; the Play view could be much larger without that bit at the bottom, as pointed out by John Nathan Corey here, at 7 mins 50 seconds; Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 15 Share Posted May 15 Submit a feature request. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted May 17 Author Share Posted May 17 Definitely will 1 Quote Link to comment Share on other sites More sharing options...
