littlespaceman Posted May 24 Share Posted May 24 I've transferred some wav files to my Stadium but forgot to set the tempo on the Helix Stadium app before I dragged the files over. When I then try to change the tempo of the Song on my Stadium it messes everything up - for example it cuts off the end of the song. Is there a way to change the tempo after creating a Song and transferring tracks, or do you have to delete that song and start all over again, setting the tempo of the song BEFORE transferring files? FWIW it probably doesn't matter much, as one of the tracks I've copied across is a click track, so I don't need the Stadium onboard tempo/click to sync perfectly, but it would be nice to achieve this if possible Quote Link to comment Share on other sites More sharing options...
jpdennis Posted May 28 Share Posted May 28 On 5/24/2026 at 1:52 PM, littlespaceman said: I've transferred some wav files to my Stadium but forgot to set the tempo on the Helix Stadium app before I dragged the files over. When I then try to change the tempo of the Song on my Stadium it messes everything up - for example it cuts off the end of the song. Is there a way to change the tempo after creating a Song and transferring tracks, or do you have to delete that song and start all over again, setting the tempo of the song BEFORE transferring files? FWIW it probably doesn't matter much, as one of the tracks I've copied across is a click track, so I don't need the Stadium onboard tempo/click to sync perfectly, but it would be nice to achieve this if possible @littlespaceman I was using the tempo within the app then ran into an issue with the way a few obscure time signatures might adversely affect the Stadium. I now exclusively use a click track. Also, you can expand the song's end flag to a point based upon the limitation I believe that is mentioned in the on line Stadium manual. jpd Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted May 28 Author Share Posted May 28 Ah, that's a good idea re moving the end point. Only thing is, I want to i increase the tempo, which shortens the song, so I guess I can't do anything about that...? Quote Link to comment Share on other sites More sharing options...
jpdennis Posted May 29 Share Posted May 29 On 5/28/2026 at 2:30 PM, littlespaceman said: Ah, that's a good idea re moving the end point. Only thing is, I want to i increase the tempo, which shortens the song, so I guess I can't do anything about that...? @littlespaceman Oh. Thanks for the clarification. I hadn't thought about the song shortening aspect. Well, the only way to test would be to adjust tempo prior to final creation. If you do that please report your finding back. I'd be interested how your click track would respond as well. Thanks again, jpd (just plain dennis) Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted May 29 Author Share Posted May 29 I'll let you know what happens if I find myself in the same situation again - like you though I think just using a click track is probably the way ahead... Quote Link to comment Share on other sites More sharing options...
