littlespaceman Posted May 29 Share Posted May 29 Something weird happens when in Snapshot Mode, and you send a MIDI message to select a Song but then press 'Cancel' on FS6 on the Stadium (to cancel that song selection) OR if you select a song then play the song via a MIDI message sent to the Stadium - in both cases the Snapshots go blank, and the only way to get them back is to cycle to FS6 (Mode) away from Snapshot and then back again. NB, this does NOT happen when Snapshots are visible in Combo Mode. See pic attached of the Snapshots blank, after doing what I've described above. Probably easier to let a video explain, but it seems I can't load anything over 3.34mb... Has anyone else come across this? Assuming this is a bug, is there a particular way to report this, or just send the info via a Feature Request? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 30 Share Posted May 30 You report a bug by opening a support ticket (follow Support link at the top of this page). If this does turn out to be a bug… great catch! Quote Link to comment Share on other sites More sharing options...
