Global input gain settings for a second guitar
xungal
Good morning. My backup guitar has lower output than my main one; this is especially noticeable on clean tones.
I’m looking for a way to match their levels globally, since the preset's input trim only applies to that specific preset.
Thanks.
There is a global setting for Input Pad which you could try. If you find it works you would only need to change it when you switch guitars, avoiding any need for preset-specific adjustments.
Ya he comprobado esa opción, y no es suficiente: no hay ajuste numérico, solo una opción para activar o desactivar el teclado.
Creo que implementar esta función sería excelente y muy práctica, ya que evitaría la necesidad de duplicar los ajustes preestablecidos.
Anyway, thank you very much for your help.
You could put a Gain block at the beginning of the chain and then add a Stomp button to toggle it on and off.  Set the level of the Gain block to whatever boost is needed to bring it to the level of your high output guitar.  You can even name the Stomp button to be "Strat" (or whatever name is appropriate).  Save the Gain block with the settings and then its easy to plant the same block into new presets.
  • 4 months later...
An adjustable global gain stage would be VERY handy. I use more than 10 presets during a gig, so adding a gain block per preset is too much hassle - especially when switching to a backup guitar. I suppose a wireless will fix that, but I like cables...
