My journey troubleshooting (and solving) connectivity between ethernet, Windows 11, Norton, and Stadium XL
PiFromBRC
FWIW, this is an AI summary of what I just went through to finish setting up my Stadium XL:
Oh yeah...and I just bought a Stadium XL.
Solved: Helix Stadium XL wouldn't connect to Windows 11 app (Code 28 / Wi-Fi Connection Required / Norton 360 Deluxe)
I wanted to post my experience in case it helps someone else.
System:
  • Windows 11
  • CyberPower PC (Ethernet connection)
  • Helix Stadium XL (Wi-Fi connection to the same home network)
  • Norton 360 Deluxe
Symptoms
  1. Connected the Stadium XL to the PC with a USB-C cable.
  2. Windows did not play the device connection sound initially.
  3. Device Manager showed:
    • Audio devices were present.
    • Helix Stadium Bulk Transfer appeared under Other devices with a yellow exclamation point.
  4. Device status showed Code 28 (drivers not installed).
  5. The Helix Stadium desktop application displayed "Wi-Fi Connection Required" even though both the PC and Stadium reported they were on the same network.
What fixed the USB driver problem
The Stadium itself had a notification (hamburger menu) to install a downloaded firmware update.
After installing the update:
  • Windows immediately played the device-connected sound.
  • The yellow exclamation point disappeared.
  • "Helix Stadium Bulk Transfer" disappeared from Other devices.
  • A new Line 6 category appeared in Device Manager with Helix Stadium XL, and Windows recognized the device correctly.
So if you see a Code 28 error, make sure the Stadium firmware is fully updated before assuming there's a USB hardware problem.
What fixed the Wi-Fi connection problem
The Helix Stadium application still reported "Wi-Fi Connection Required."
After troubleshooting, I discovered the issue was Norton 360 Deluxe Smart Firewall.
As a test, I temporarily disabled Smart Firewall for 5 minutes. The Helix Stadium application connected to the Stadium immediately.
That confirmed the firewall was interfering with local network discovery.
Interestingly:
  • Program Control entries were already set to Allow.
  • There were no custom Traffic Rules blocking Line 6.
  • My Ethernet network profile in Windows was already set to Private.
After additional troubleshooting, everything began working normally and the application now connects successfully.
Suggestions if you're having the same problem
  • Update the Stadium firmware first.
  • If Device Manager shows Code 28 for Helix Stadium Bulk Transfer, don't panic—the firmware update may resolve it.
  • Verify your Windows network profile is Private.
  • If you're running Norton 360 Deluxe, temporarily disable Smart Firewall as a test. If the editor immediately connects, you've confirmed the firewall is involved.
Hopefully this saves someone else a few hours of troubleshooting.
