Stadium Headphone Volume Significantly Lower than OG Helix
tc1072
Just got the Stadium XL earlier today, coming from owning and using a Helix LT since the day it launched.   I play exclusively through a great set of Sennheiser open back headphones, and am now seeing the volume from the Stadium is WAY lower (even at max) to the LT not even being close to maxed on it's volume.... .  Is there anything in the settings to add more volume to the headphone out?  Or if I added a headphone amp would that actually help raise the volume (and I HATE to have to add to an already pricey purchase just to make it equal to what I had...)
It could be a settings issue. You're probably already aware of the Matrix mixer in Stadium, and that the 1/4", XLR, and headphones output levels can be controlled individually or all together. There's also a Global Setting that controls 1/4" and XLR output levels.
This is just a guess but the latter may interact with the former. In other words, if you have the XLR outputs set to Mic rather than Line, and you have the mixer controls such that all outputs are controlled together, your headphones output might be lower than expected. Make sure the headphones output is controlled independently in the Matrix.
