BigDaddyRC Posted July 31 Share Posted July 31 I play in a band that drops a number of songs by a semi tone and I am tired of continually changing guitars. I find the Poly Capo on the Helix to be an absolute resource pig and difficult to incorporate in my current patches. Any alternatives other than buying a dedicated pedal to do this? Quote Link to comment Share on other sites More sharing options...
jester700 Posted July 31 Share Posted July 31 Unfortunately, those are your choices. Well, unless you're flush with cash, in which case a Stadium should fix ya right up! ;-) Quote Link to comment Share on other sites More sharing options...
theElevators Posted August 1 Share Posted August 1 Before the "along came poly" release, I had one song that needed standard D tuning. I used the regular transposer "simple pitch" for it and it sounded just fine. It is not the "poly" effect, but it can definitely transpose multiple notes at the same time, absolutely no problem. If you just play distorted chords, lots of power chords, it will work fine. For all your shimmering clean stuff, you can forget about it, it will be glitchy. So the old transposer is just a little bit less accurate, but works just fine. Try it. Regarding the poly capo, yes it does take up a lot of DSP, but I managed to rearrange all my stuff on the Helix: moved stuff around and down to the 2nd line, so I can have a reasonable preset with all the necessities no problem. I played with a singer who often changed keys, so I always had a poly capo in every preset just in case. I like it, it does have some latency, but for 1-2 semitones it works great. Your last option is to get the drop pedal or something similar. People say they work great. 2 Quote Link to comment Share on other sites More sharing options...
theElevators Posted August 7 Share Posted August 7 There's this new pedal too: Quote Link to comment Share on other sites More sharing options...
