L3m Speaker Snaps Shortly After Power Switch Turned On
Hi there...purchased a pair of L3m speakers.  When I power one of them on..there is the usual momentary delay and then you hear the speaker make a subtle noise as it kicks on. That is normal. But on the other one....it has the usual momentary delay and then it snaps bfriefly and kind of loud I think as it kicks on.  Anyone ever experience this??? After it is on there is no issue...only at start up does it do this snap noise....
Does this happen only with the one speaker without any other connections? To test, disconnect both speakers from all other devices, including each other if using L6 LINK, and try powering each on in isolation.
This will determine whether the snap is within the speaker itself or related to the connections.
Do you happen to have the Line 6 M20d mixer? If so you could try reinstalling the speaker firmware.
Otherwise I guess you have to decide whether this is sufficiently troublesome for you to look into a warranty repair.
