defmuse Posted Sunday at 01:58 PM Share Posted Sunday at 01:58 PM I don't know how I've never run into this issue before, but I'm trying to sort out all my IRs; deleting the ones I don't use, and add some new ones. I made a list of the ones that are being used in my presets. I then went into HX EDIT, and realised that I can't see most of the complete names of the IRs. I can extend the right panel of the Edit window (that displays the Edit window), but can't extend the left panel (that displays the Presets, IRs + Favorites). Has anyone else had an issue with this? It's a pain, because I want to select all, and then simply de-select the ones I DON'T want to delete off of my Helix, while clearing out the rest. Now, I feel like I'm going to have to clear out all, one by one...? Quote Link to comment Share on other sites More sharing options...
silverhead Posted Sunday at 04:29 PM Share Posted Sunday at 04:29 PM It’s been a while since I’ve used Helix or HX Edit, bit it occurs to me that the set of IRs that are loaded into HX Edit at startup are the ones that are contained in a specific IR folder on your computer, along with the preset and setlist files contained in sibling folders. Perhaps you can use that specific folder, not HX Edit, to see the full filenames and edit/delete accordingly? Presumably the next time HX Edit is launched your set of loaded IRs will be as you wish. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted Sunday at 04:39 PM Share Posted Sunday at 04:39 PM From any preset that uses IRs, you can scroll the IR name in the IR Block, and the full name is displayed along with its position in the IR list. The dropdown arrow displays the full list in scrollable form. 2 Quote Link to comment Share on other sites More sharing options...
defmuse Posted Sunday at 07:00 PM Author Share Posted Sunday at 07:00 PM On 8/23/2026 at 9:59 PM, silverhead said: It’s been a while since I’ve used Helix or HX Edit, bit it occurs to me that the set of IRs that are loaded into HX Edit at startup are the ones that are contained in a specific IR folder on your computer, along with the preset and setlist files contained in sibling folders. Perhaps you can use that specific folder, not HX Edit, to see the full filenames and edit/delete accordingly? Presumably the next time HX Edit is launched your set of loaded IRs will be as you wish. Yeah, i cross-referenced it that way, but still have to delete them a few at a time, as there were a number of IRs I was not able to see the full names of on HX Edit. There are quite a few IRs that have similar names, with only a few characters that differ (which don't show up, as there is not enough room in the panel on HX Edit). This just takes a lot more time, as opposed to selecting all in the panel itself, de-selecting the ones I don't want to delete, and then clearing the ones i DO want to delete. I'll have to do this long process each time I want to try out new IRs / change them around. But thanks a lot for your suggestion! Quote Link to comment Share on other sites More sharing options...
