Aidanism Posted September 6 Share Posted September 6 Hi, I have been trying to figure out the 4 cable method with the HX Effects. I have a Laney L5 tube amp which has a drive channel that allows you to overdrive the signal while keeping the volume low. However, using the 4C preset as a template, with an FX loop block, I am unable to overdrive the signal to my amp and can only achieve any sort of overdrive/distortion by adding Helix "pedals" to the chain. Any gain/volume adjustments I make on the amp don't affect the sound in any way. I'm wondering if this is normal or if I'm missing something? I would really like to be able to start with my amp's own overdriven signal before the effects. Unfortunately I am not very technically-minded so if anyone could give me a very basic answer I'd be really grateful. Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 6 Share Posted September 6 What if you connect the HX FX Send cable (FX Loop Out) to your amp’s drive channel input rather than the normal channel input? 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 6 Share Posted September 6 1.Check the physical cable connections: Ensure all 4 cables are plugged into the correct jacks: Guitar -> HX Effects IN HX Effects Send 1 -> Laney Guitar Input (front panel) Laney FX Send -> HX Effects Return 1 HX Effects Out -> Laney FX Return 2.Turn ON the FX Loop block: In your HX Effects preset, locate the FX Loop 1 block and make sure it is switched ON (active). Verification: Toggle the FX Loop block on/off. When it is OFF, you should hear no sound at all (or a very quiet clean sound). When it is ON, your Laney's preamp control knob should instantly start adding overdrive. 1 1 Quote Link to comment Share on other sites More sharing options...
Aidanism Posted September 6 Author Share Posted September 6 Thank you so much. In fact it was that the FX loop block wasn't switched on. It seems so obvious but it just hadn't occurred to me that a non-"pedal" block needed to be switched on. I'm really grateful for the helpful comments. Quote Link to comment Share on other sites More sharing options...
