LoudenDeri Posted October 8 Share Posted October 8 Is there a way to NOT mute the microphone channel while tuning guitar? I usually talk to the audience while tuning. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 9 Share Posted October 9 Check the Tuner Input selection(s) in the Tuner parameters. Make sure Mic is excluded. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted October 19 Share Posted October 19 On 10/9/2026 at 1:52 AM, silverhead said: Check the Tuner Input selection(s) in the Tuner parameters. Make sure Mic is excluded. I presume your reply refers to the Stadium XL, which has a separate Mic input. The Stadium doesn't, so I am using Return 1 for a Mic input (the mic is a wireless one using a 1'4" receiver). It's been annoying me for a while that I can't find a way to mute the guitar when the Tuner is active, but keep the Mic input (ie, Return 1) unmuted. Any ideas on this, please? Quote Link to comment Share on other sites More sharing options...
rwandering Posted October 19 Share Posted October 19 Both the Helix Stadium Floor and XL have a Mic input. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted October 19 Share Posted October 19 On 10/19/2026 at 7:09 PM, rwandering said: Both the Helix Stadium Floor and XL have a Mic input. Sorry, my bad! Of course it does - I'm confusing myself (one significant downside of getting older :o( What I should have said is that I use the Return 1 input, BECAUSE I'm using a (cheap/Amazon) wireless mic, which has a 1/4" receiver. I can't find a way to Mute only the guitar when the Tuner is active, in this case - so it does mute the mic as well. Any suggestions for an internal work-around (other than get a wireless XLR mic or even an 1/4" to XLR adaptor). Or maybe it's a feature request to add the ability to mute different inputs Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 19 Share Posted October 19 On 10/19/2026 at 2:59 PM, littlespaceman said: … I can't find a way to Mute only the guitar when the Tuner is active, in this case - so it does mute the mic as well…. The Tuner should mute only the selected Input(s). Assuming your guitar is connected to the Guitar input set the Tuner input to Guitar, not something like Multi. If the Tuner Input is set to only Guitar, then other inputs such as XLR or Return should not be recognized by the Tuner and hence should not be muted. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted October 20 Share Posted October 20 On 10/19/2026 at 11:18 PM, silverhead said: If the Tuner Input is set to only Guitar, then other inputs such as XLR or Return should not be recognized by the Tuner and hence should not be muted. This is exactly the problem; in my case, I have my guitar connected via the Instrument input, and I have the Tuner Input selected to Instrument only. I have the output set to 'Mute', which according to the manual = Mute: The input signal is muted completely (although it respects the Tuner Trails setting). This implies to me that it should mute only the input signal selected in the Tuner Input setting, and not ALL the inputs (otherwise what's the point of having selectable tuner inputs?) But for reasons I don't understand, when set up this way it also mutes everything else, including the Return 1 input, and therefore my mic... I've also tried setting Tuner Trails to 'On' which according to the manual = Tuner Trails Determines whether the natural decay of Delays, Reverbs, FX Loops, and the Aux/Return input continue when the Tuner screen is opened. Does not apply if Tuner Output is set to “Processed.” However, on the Helix screen, the explanation of the Tuner Trails function says on Aux/Return 3/4 continue, which is a significant difference as the Stadium Floor doesn't have a Return 3/4, it only has Return 1/2 Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 20 Share Posted October 20 Thanks for your detailed investigations, @littlespaceman. This sounds like a bug. I suggest that anyone experiencing this open a support ticket. Please report back to let us know the response. Quote Link to comment Share on other sites More sharing options...
littlespaceman Posted October 20 Share Posted October 20 On 10/20/2026 at 1:39 PM, silverhead said: Thanks for your detailed investigations, @littlespaceman. This sounds like a bug. I suggest that anyone experiencing this open a support ticket. Please report back to let us know the response. I've sent a bug report so hopefully this is now on radar for the developers... 2 Quote Link to comment Share on other sites More sharing options...
LoudenDeri Posted yesterday at 04:47 PM Author Share Posted yesterday at 04:47 PM Thanks for chiming in on this @littlespaceman Do you know if I should submit a support ticket as well? Or? Quote Link to comment Share on other sites More sharing options...
silverhead Posted 21 hours ago Share Posted 21 hours ago Yes, open a support ticket also. The more users reporting a bug increases the chance that it will be fixed sooner than later. Quote Link to comment Share on other sites More sharing options...
