joeloduca Posted Saturday at 03:07 PM Share Posted Saturday at 03:07 PM Hello All, Trying to learn how to make a trouble ticket with Line 6 on this, I've done some extensive testing and I know MIDI dangerously too well - I think there is an obvious OS/Firmware issue in MIDI on the helix stadium and this issue did NOT exist in my previous Helix Floor. I will test my Helix stomp to see if there is a problem there but I am almost convinced there is NOT. I use MIDI controllers on every preset and I like to have multiple MIDI CC's controlling multiple parameters.. IN my opinion, this is a way better alternative to SNAPSHOTS, you can add MIDI control flexibility to EVERY PRESET. You can also do gain compensation things that are a little harder to pull off on SNAPSHOTs. Here is an example how I do this: I set MIDI CC #14 to control the DRIVE of an amp. Simple law of physics: when DRIVE GOES UP, VOLUME ***ALSO GOES UP - sometimes SIGNIFICANTLY. To help compensate and make distortion more "tameable", I set the same CC#14 to control the same amp's LEVEL. So when we turn up DRIVE/DISTORTION, VOLUME dips a little to try to keep a more consistent overall volume.. Its not perfect, but I think it absolutely awesome to TAME the volume of distortion. Anyway, when I set up **JUST the drive to MIDI CC14, it works GREAT in the STADIUM with my external MIDI controller (and I have many of them that all do the exact same thing).. The moment I set up a second (of the same CC14) to another parameter (like amp level), MIDI OFTEN STOPS.. -- and by the way, USB MIDI does the exact same problem. anyone know how to get a trouble ticket into Line 6 to work on this in future releases of Firmware? Thanks MUCH! Joe Quote Link to comment Share on other sites More sharing options...
silverhead Posted Saturday at 04:37 PM Share Posted Saturday at 04:37 PM On 10/10/2026 at 11:07 AM, joeloduca said: … anyone know how to get a trouble ticket into Line 6 to work on this in future releases of Firmware? Follow the Support link at the top of this page. Then select Contact Support. Quote Link to comment Share on other sites More sharing options...
