barnsleyboy Posted 10 hours ago Share Posted 10 hours ago Ok, so here's the culprit: And here's the problem: Looks like a crack in the scribble strip screen, but it's a cat hair inside Grrrr! I've taken the back cover off and blasted it with air, but I can't dislodge it. Before I start randomly taking screws out, does anybody know which ones I need to remove to ease the board away enough to give it another blast with compressed air to remove it? ... and yes, I will take full responsibility if I break it, so no litigation worries :-) Any help from you wonderful people gratefully accepted. Quote Link to comment Share on other sites More sharing options...
theElevators Posted 9 hours ago Share Posted 9 hours ago I have a cat as well, and I have a habit of vacuuming the Helix once a week. Expression pedal, around all the buttons, everything. Then I wipe it down with some Windex. Also when not in use, I cover it with microfiber towel and plastic that the Helix came in. No such issues for me. While you're disassembling the Helix, take liquid DeoxIT and add it to every microswitch aka tactile switch, then press a few times. That way you won't have any footswitch issues for the next 2 years Quote Link to comment Share on other sites More sharing options...
barnsleyboy Posted 9 hours ago Author Share Posted 9 hours ago Fantastic - Hair is now out, unfortunately I reassembled and have left some dust and debris behind in another scribble strip window, , so need to take it apart again. Obviously these are assembled in a dust free factory environment. I'll need to be a bit more careful! Quote Link to comment Share on other sites More sharing options...
LuniTunes Posted 3 hours ago Share Posted 3 hours ago I wonder what it would take to establish and maintain a small dust-free clean room in a residential setting. People have walk-in humidors and climate-controlled wine cellars; why not contaminant-controlled nerd rooms for dweebing around with sensitive electronics? 1 Quote Link to comment Share on other sites More sharing options...
