monika532lara Posted 18 hours ago Share Posted 18 hours ago Hi everyone, I’ve been using my Line 6 unit (Helix / HX Stomp) for live gigs recently, and I'm running into some inconsistent volume levels when switching between clean, crunch, and lead snapshots—as well as between entirely different presets. Even when the output meters look fairly close at home, the lead tones sometimes get buried in the live mix, or the clean tones jump out a bit too much. I’d love to hear how other gigging players handle gain staging and volume leveling across their patches. Specifically: Where in the signal chain do you adjust your snapshot levels? (e.g., Amp Channel Volume, Output Block gain, or a dedicated Gain block at the end of the chain?) Do you rely on the built-in output meters, a DAW LUFS/dB meter, or strictly your ears at stage volume? Any tips for making lead boosts cut through a full band mix without just slamming the FOH engineer with massive dB spikes? For context, I’m running direct to FOH (XLR/1/4" out) with Global EQ engaged for high/low cuts. Any advice or workflow tips would be greatly appreciated. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
theElevators Posted 10 hours ago Share Posted 10 hours ago The best way to adjust the volume is to have mixing monitors and play your instrument, maybe even run a looper, and quickly toggle between the snapshots. If I'm checking how all different snapshots work in relation to each other, sometimes I just record myself into a DAW in stereo and switch the snapshots. Then I can see the wave amplitude and also hear how it sounds. Using tools to analyze loudness is not a good approach IMO. Because depending on EQ, some sounds appear more piercing and therefore louder than the others. So my advice is to use your ear, figure out the formula that works, and do it everywhere. For example, I know that in my solo I need to boost 2 KH by exactly 10 DB by putting an EQ block right before the amp. That setting works for me. I've tried less drastic settings, but when reviewing concert footage I saw that the sound guy had to turn me up me for the solos, and then bring it back. So I'm using the same trick across the board. My solos are not necessarily louder, as they are way more piercing, which is exactly what helps them cut through and not get buried. While we are on the topic, I've mentioned this many times. If you want to cut through, get rid of your reverb and use stereo ping-pong delay instead. Or use ducked reverb, otherwise it buries your sound. There are times when you want the reverb, and I do have it sometimes, but it's definitely not helping me cut through! also.... Oftentimes "crunch" needs to be louder than clean.... and sometimes you may want a loud clean surf sound, so it's all subjective. You need to dial in the perceived loudness so all sections are exactly as they should be. It needs to fit the song you are playing. In terms of how to level different snapshots, you can do it in many different ways. Most modulation effects/delays/reverbs have an output level parameter, so you can use that. Sometimes the mix parameter of certain blocks can also be used to adjust the balance. And if you have an EQ block, you can also turn down the volume on that for specific snapshots. I almost never touch the amp or the output block to level my sounds, it's almost always adjusted in the "additional" blocks that get turned on/off. The only time I touch the output blocks' output if I want my exact sound just 5 db lower for special effects when starting a song, or something along these lines--I may even send the signal to the left side only as well. I also never turn off my distortion, but simply cut the initial volume either on my guitar or using a fixed volume block. That way the volume remains consistent, but the amount of distortion is reduced as needed. It took me a while to find the right distortion that can do that (legacy classic distortion). Once I set things up at home, I take it to a rehearsal and then see what needs to be turned up/down. I listen to the rehearsal recording and see what needs to be louder. Or I can sometimes hear it myself what is out of place, and I fix it. After many such iterations, I have the most perfect balanced snapshots that require very little sound guy intervention. Don't forget that drums and other instruments can play louder or softer depending on the song/song section, so your output needs to match what is happening in the song as well! Ultimately, to really test your gear, you need to do it at a venue. That's what pro bands do, they rent out a theater and rehearse and work out what needs to be turned up/down. Until you do it on a big PA, you may not hear it properly. And also, the sound mix varies from one PA to another, so sometimes you need to tweak things for that specific venue/PA--been there and done that... Hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
stapani Posted 8 hours ago Share Posted 8 hours ago When I don`t trust my ears, I use this (but I ain`t searching perfect feel) : https://getmetermaid.com/ Quote Link to comment Share on other sites More sharing options...
