actdmusic Posted April 28, 2014 Share Posted April 28, 2014 Hi Does anyone seen this on the M20d? If I leave the console on with nothing assigned to the bottom encoders 3,4 and 6 (counting from the left) they light blue after a while. :blink: :wacko: Pic: Any ideas? :huh: Quote Link to comment Share on other sites More sharing options...
dboomer Posted April 28, 2014 Share Posted April 28, 2014 Are you seeing anything else lit up in the I/O panel (top of the setup page) besides the two sources I see on your screen? Quote Link to comment Share on other sites More sharing options...
actdmusic Posted April 28, 2014 Author Share Posted April 28, 2014 Didn't check... I will and report back. Thanks Quote Link to comment Share on other sites More sharing options...
actdmusic Posted April 29, 2014 Author Share Posted April 29, 2014 Nop, there's no indication of any thing connected on the IO panel... Quote Link to comment Share on other sites More sharing options...
actdmusic Posted April 30, 2014 Author Share Posted April 30, 2014 I was paying attention today. The blue lights start fading in very slowly when I leave the console on for a while. Probably it's heat associated? Quote Link to comment Share on other sites More sharing options...
JeffersteinVS Posted April 30, 2014 Share Posted April 30, 2014 probably firmware related. I think theres some bugs in the firmware that need to be addressed for sure. 1. headphone out jack looses right side after a period of time 2. The lag that occurs during use when 16 channells are active 3. During recording with 16 channells lag is unbareable 4. using more than one ipad = lagging Quote Link to comment Share on other sites More sharing options...
dboomer Posted April 30, 2014 Share Posted April 30, 2014 I think you'll find your "lagging" issues are related to using a dongle USB Wi-Fi stick. Switching over to a regular router will improve it. Quote Link to comment Share on other sites More sharing options...
dboomer Posted April 30, 2014 Share Posted April 30, 2014 Nop, there's no indication of any thing connected on the IO panel... OK. Try building a new setup. Does it still happen? Quote Link to comment Share on other sites More sharing options...
actdmusic Posted April 30, 2014 Author Share Posted April 30, 2014 Been testing all afternoon... It happens in any setup, fresh or previously saved, were those 3 encoders are not signed to anything. The 3 encoders stay blue even when changing between setups. They only change color when changing to a setup were they are assigned to something. When I turn on the mixer the LEDs appear normal (turn off if nothing is assigned) but they start to very slowly light up in blue (fading in). If I turn off the mixer and turn it on right a way (1m or so after) the LEDs will be on (blue) even during power up. If I turn off and wait 10m or more they will be off next time I power up. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted May 1, 2014 Share Posted May 1, 2014 probably firmware related. I think theres some bugs in the firmware that need to be addressed for sure. 1. headphone out jack looses right side after a period of time 2. The lag that occurs during use when 16 channells are active 3. During recording with 16 channells lag is unbareable 4. using more than one ipad = lagging Agree with headphone issue. Don't know about using all 16 channels. I only use 8. But sometimes, I notice a very slow setup or scene loading. Used to be almost instant. I only have a coupe setups, with one or two scenes each. It was definitely after the last firmware update, but, it is far from unbearable for me. And there is a couple other issues that I know Line 6 is aware of. I am still going to be investigating my "in and out" aux A channel which I don't believe is hardware related. But can't say for sure. Going to try the idea in the other post. And I haven't had any encoder light up unexpectedly. But I guess firmware. It is a heck of a board, and I don't know the testing procedures, but surely everything could not be tested? Every combination of something we might do? I know I would be thinking "But who would EVER do that???". I am not a programmer, and have no idea what goes on. I would always be a beta tester though. Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 1, 2014 Share Posted May 1, 2014 Likely not firmware. If it were firmware it would pop up on every unit. Probably a hardware issue that should be seen by the service department. As far as scenes and setups. ... Scenes should load very quickly but setups take a few seconds. Quote Link to comment Share on other sites More sharing options...
actdmusic Posted May 4, 2014 Author Share Posted May 4, 2014 So... what should I do? :unsure: . Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted May 5, 2014 Share Posted May 5, 2014 Likely not firmware. If it were firmware it would pop up on every unit.I am not the most computer literate, but I understand "firmware" to be very similar to "software". Maybe a bit of a combination of software and hardware? But if it is at all like software, then it may be safe to assume the same problems may very well not pop up on every unit. We all use them differently, with very different demands on the system. And likely very different procedures and steps to do similar functions. I think we all know that what happens in one persons software, may never happen in another person's software who may be using the exact same version of the software. Or, is firmware much different from software and far more similar to hardware? Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 6, 2014 Share Posted May 6, 2014 Firmware is just more permanently installed software. Quote Link to comment Share on other sites More sharing options...
