virtzberg Posted May 6, 2014 Share Posted May 6, 2014 I have 2 guitars that are connected to the HD500x. The first is Tom anderson which is connected to the "guitar" input and the other is Variax Jtv69 which is connected to the Variax input. How to do a setting that the Anderson will go to an amp and the variax will be send direct to the PA?I will appreciate giving the instructions step by step...thanks. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted May 6, 2014 Share Posted May 6, 2014 You will need to set up a dual-amp, dual-path, panned hard left and right patch. I created a quick "Sample" patch which illustrates this in a basic manner. Input 1= variax Input 2 = guitar FS1= boost comp / red comp FS2 = tube drive / screamer FS3 = '62 spring / hall reverb FS4 = digital delay / dynamic delay I set the footswitches in a simple way, it's not ideal for actual playing, because each FS turns on/off both channels effect. IE, fs1 will toggle both compressors, fs2 will toggle both drives, fs3 both reverbs, fs4 both delays. You need to, as you will see in the patch (it's in the attached .zip file) drag all the pre and post FX blocks into the two amp channels so as to keep the two inputs divided. The mixer also needs to be panned hard left and right, as it's set in the patch. In this case "path A" is panned left, and that's the Variax, "path B" is panned right, and that's the Guitar. Keep the output mode as "studio direct". Run the left XLR out to the PA. Run the right 1/4" out to the FX return on your amplifier. Dual Tone_Left-Right.zip 1 Quote Link to comment Share on other sites More sharing options...
jandrio Posted May 7, 2014 Share Posted May 7, 2014 check also this similar post: Balancing Two Guitars Into Pod Hd500x Quote Link to comment Share on other sites More sharing options...
virtzberg Posted May 7, 2014 Author Share Posted May 7, 2014 Thanks very much! 1 Quote Link to comment Share on other sites More sharing options...
