inblut Posted May 13, 2014 Share Posted May 13, 2014 Hello, I have been reading several posts and found no answer for my problems.First of all, I´m connecting the unit the normal way for a 4 cable method connection.Apart from the fx loop volumes, what should be the position of the bypass know on the amp menu?I have turned it off. Should this knob be all the way up? Should it be at 50%? On the chassis, the AMP / LINE button. If turned to line, the amount of volume is absurd, specially if the bypass knob is cranked up. Should I turn the bypass all the way up and have the chassis option on the AMP? Should the fx go into the amp as a line signal or amp signal? Thank you so much for your time. Regards, Ricardo Quote Link to comment Share on other sites More sharing options...
inblut Posted May 13, 2014 Author Share Posted May 13, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
