folden Posted May 17, 2014 Share Posted May 17, 2014 Have had big problems with updating the flash memory on my new POD HD400. 2.01 simply wont work on my unit. Near the end of the Flash Memory-update, it shows some error message containing some information about MIDI-interface (i use USB to update). Have tried all the solutions mentioned in other topics in this forum, without luck. After "Factory Reset", i get the DSP Boot failure, and my POD is filled with nothing. Have tried flashing it in safe mode, have tried everything. The one solution i found, was to rollback/update from file down to 1.31. 2.01 won't work in any way. So - since it worked rolling back to 1.31, i have in some ways eliminated that the problem is on MY end of this. Nothing wrong with computer/drivers etc. The problem comes from malfunctions in the software Line6 issues. So please - Give us an update that work (or instructions to a method that will actually update my firmware), and provide us with an solution. I suppose other people are having problems as well. 2 Quote Link to comment Share on other sites More sharing options...
tsvetok_x Posted May 17, 2014 Share Posted May 17, 2014 I have the same problem with Firmware 2.01. I can't upgrade my POD HD400!!! But I can't rollingback to 1.31 too :( Any help from support team? Quote Link to comment Share on other sites More sharing options...
alienux Posted May 18, 2014 Share Posted May 18, 2014 I have the same problem with Firmware 2.01. I can't upgrade my POD HD400!!! But I can't rollingback to 1.31 too :( Any help from support team? Have you opened a ticket with them? 1 Quote Link to comment Share on other sites More sharing options...
tsvetok_x Posted May 18, 2014 Share Posted May 18, 2014 Have you opened a ticket with them? Excuse me, what do you means? ticket? Sorry.. I can't understand it. :( Upgrading resolved by downloading file "FlashMemory 2.01" from support page to my PC and upgraded with "Monkey" :) Thank you very much for your atention! Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 18, 2014 Share Posted May 18, 2014 He means a support ticket, which is a means of contacting Line 6 technical support to work directly with you, one-on-one, to resolve your specific issue. To open a ticket, follow the Support tab at the top of this page, and select Contact Technical Support. 1 Quote Link to comment Share on other sites More sharing options...
tsvetok_x Posted May 18, 2014 Share Posted May 18, 2014 He means a support ticket, which is a means of contacting Line 6 technical support to work directly with you, one-on-one, to resolve your specific issue. To open a ticket, follow the Support tab at the top of this page, and select Contact Technical Support. Ok. It's clear. No, I had not. Only had used "try and error" method :) Good Luck! Quote Link to comment Share on other sites More sharing options...
folden Posted May 18, 2014 Author Share Posted May 18, 2014 I have the same problem with Firmware 2.01. I can't upgrade my POD HD400!!! But I can't rollingback to 1.31 too :( Any help from support team? I had to reinstall drivers, boot up the POD in safe mode (power on while holding in A-button) in order to rollback. 1 Quote Link to comment Share on other sites More sharing options...
tsvetok_x Posted May 18, 2014 Share Posted May 18, 2014 I had to reinstall drivers, boot up the POD in safe mode (power on while holding in A-button) in order to rollback. R: Upgrading resolved by downloading file "FlashMemory 2.01" from support page to my PC and upgraded with "Monkey" :) Quote Link to comment Share on other sites More sharing options...
folden Posted May 18, 2014 Author Share Posted May 18, 2014 Okay. Tried that aswell, didn't work yesterday. DSP boot failed from both Monkey-downloaded 2.01 and upgrade from file 2.01. Quote Link to comment Share on other sites More sharing options...
tsvetok_x Posted May 18, 2014 Share Posted May 18, 2014 Okay. Tried that aswell, didn't work yesterday. DSP boot failed from both Monkey-downloaded 2.01 and upgrade from file 2.01. You should use "upgrade from file..." Quote Link to comment Share on other sites More sharing options...
folden Posted May 18, 2014 Author Share Posted May 18, 2014 You should use "upgrade from file..." Did that yesterday aswell. But downloaded again today, replaced the file i downloaded yesterday. Also, a few reboots between the attempts. End of story anyways, it worked! :) 1 Quote Link to comment Share on other sites More sharing options...
bjnette Posted May 19, 2014 Share Posted May 19, 2014 WELL DONE GUYS Quote Link to comment Share on other sites More sharing options...
jeremybarnes1 Posted May 20, 2015 Share Posted May 20, 2015 So I have done exactly what you guys said. Downloaded from the website and then updated from file. Have done this numerous times. Still no luck. What exactly did you have to do to get it to work? Quote Link to comment Share on other sites More sharing options...
tfreitas Posted May 21, 2015 Share Posted May 21, 2015 PLEASE HELP ME, MY AFTER THIS UPDATE TO SUBMIT THE FOLLOWING MESSAGE: DSP BOOT FAILED AND THEN THE DISPLAY IS WHITE WITHOUT ANY INFORMATION. CONCLUSION: THE COMPUTER DOES NOT IDENTIFY ACROSS USB, I AM NOT USING IT AS HD300 LOCK SCREEN THAT DO NOT HAVE ACCESS TO THE BANK OF EFFECTS. HELP HELP HELP BRASIIIIIIIIIIIL Quote Link to comment Share on other sites More sharing options...
clalem Posted May 28, 2015 Share Posted May 28, 2015 R: Upgrading resolved by downloading file "FlashMemory 2.01" from support page to my PC and upgraded with "Monkey" :) Worked fine for me, resolved my problem. Thank you Quote Link to comment Share on other sites More sharing options...
Psynogen Posted June 12, 2018 Share Posted June 12, 2018 Pls help mMe. I just bought a POd HD400 and I got a gig in a month. i can only download monkey version 1.74 (latest is 1.76). Anyways I upgraded firmware, usb firmware and flash memory and upgraded my Pod HD400. Unfortunately my pedal calibration has gone. The "thumb button" or the D switch on the pedal works as I can switch between Wah and Vol. Even after initiating a factory reset, when it gets to the calibaration part, no matter how hard I push and wait the calibration process does not start. When I bought it, wih the old drivers, it was working perfectly, this upgrade has somehow screwed the hardware through Monkey, whtaever it id whle installing the drivers, and firmware. The switch works, there is no doubt. Can i go back to the old drivers, flash memory and revert back from the upgrade and get my volume pedal working correctly? the only sound i get is if i switch the pedal to Wah, if i swtch to Vl, there iss no sound!? Pls help me.... Quote Link to comment Share on other sites More sharing options...
