different volumes for each tone
lcasalini
When I swiitch between saved tones, I find the output volume to change dramatically from one tone to the other. This can be a problem, espcially palyng with a band, because I have to reaggust the main volume every time. Is there a way to  fix this?
I addressed this issue with Line6 support and they instructed me to check all three options for dialing volume: Master (red), Guitar (white), and Amp (in Amplifi Remote only).
The one you might forget is the Amp. Once you have the tone, go to the Amp and then dial tone.
Also, when you go to "Edit" a tone, it usually opens up in the "Amp/Cab" screen. There is also a "Vol" icon there where you can adjust the volume and even it out with other tones.  After adjusting, be sure to click it on and save your settings.
