scottyo78 Posted June 10, 2014 Share Posted June 10, 2014 Hi, The audio feedback issue that is supposedly fixed by version 2.10 has never been an issue with my HD500. I run out both of the 1/4" outs to two separate (stereo) amps, record and play live to PA using both of the XLR's and I run HD500 Edit via USB... and yet I've never had a feedback issue. Has anyone noticed any other inherant benefits? For example... Does the tempo update on the actual unit now via HD500 Edit? Is the tuner visibly available on the HD500 Edit panel? Thanks, Scott Quote Link to comment Share on other sites More sharing options...
lachinelli Posted June 10, 2014 Share Posted June 10, 2014 I guess you've been lucky; I had that feedback issue happen 3 or 4 times in the 2 years I've owned the pedal. I'd say it rarely happens and when it does, you can get rid of that by changing patches. That's why I've played live with the POD, otherwise, if the problem was persistent I wouldn't have used it live. But the thing is it will happen sometime in the future so I'd recommend you update following all the procedures (backup, update, reset to default, calibrate pedal) so you don't have any issues. 2 Quote Link to comment Share on other sites More sharing options...
scottyo78 Posted June 11, 2014 Author Share Posted June 11, 2014 OK, I guess that's enough evidence to warrant updating. I'm one who tends to follow the old adage: "If it ain't broke, don't fix it". ;) Does the update still require a re-cal of the pedal and a global update/reset of some kind? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 12, 2014 Share Posted June 12, 2014 Yes - global parameters reset followed by pedal recalibration. Quote Link to comment Share on other sites More sharing options...
scottyo78 Posted June 12, 2014 Author Share Posted June 12, 2014 Thanks Silverhead for the confirmation! I haven't upgraded for awhile and it's good to get a sanity check. ;) Quote Link to comment Share on other sites More sharing options...
