ChristianArnold Posted June 25, 2014 Share Posted June 25, 2014 Can the Variax 700 bass do alternate tunings and if so, how? Quote Link to comment Share on other sites More sharing options...
clay-man Posted June 25, 2014 Share Posted June 25, 2014 Can the Variax 700 bass do alternate tunings and if so, how? Alternate tunings are assigned by a patch by patch basis through workbench. Patches = every pickup selection position for each bank on the model knob. Once you change the tunings through workbench, it will always be that tuning on that patch and you cannot disengage, change the guitar model that's tuned to that tuning without doing it through workbench again, this means if you want a Strat in E standard and a Strat in Drop D, you have to have 1 bank have the 5 pickup selections be in E standard then copy those to another bank and make all the pickup selections Drop D. I suggest using Custom 1 and 2. It depends on what you value more, different models or different tunings. The more tunings you want the more models you'll have to replace on your model select roster. Quote Link to comment Share on other sites More sharing options...
ChristianArnold Posted June 26, 2014 Author Share Posted June 26, 2014 Alternate tunings are assigned by a patch by patch basis through workbench. Patches = every pickup selection position for each bank on the model knob. Once you change the tunings through workbench, it will always be that tuning on that patch and you cannot disengage, change the guitar model that's tuned to that tuning without doing it through workbench again, this means if you want a Strat in E standard and a Strat in Drop D, you have to have 1 bank have the 5 pickup selections be in E standard then copy those to another bank and make all the pickup selections Drop D. I suggest using Custom 1 and 2. It depends on what you value more, different models or different tunings. The more tunings you want the more models you'll have to replace on your model select roster. You are thinking of the JTV or the regular variax. I'm talking about the bass variax. Quote Link to comment Share on other sites More sharing options...
clay-man Posted June 26, 2014 Share Posted June 26, 2014 You are thinking of the JTV or the regular variax. I'm talking about the bass variax. Ah sorry, I misread the title. It seems like you can't. Not 100% sure. It says it doesn't have workbench support, and I don't think there was any other way to change tunings other than through workbench prior to the JTVs. Detuning a Variax physically can sometimes be a bit sketchy as it needs the tension of the strings to be on the piezos to respond properly, so if you ever do tune down physically you might need thicker gauge strings. Quote Link to comment Share on other sites More sharing options...
quadcabby Posted January 12, 2015 Share Posted January 12, 2015 The simple answer, although I'm late with it, is no. It doesn't work with the Workbench software. Quote Link to comment Share on other sites More sharing options...
ThorntonDavis Posted January 12, 2015 Share Posted January 12, 2015 As mentioned in the post above, no alternative tuning are not available for the 700/705 basses. Apparently L6 stopped developing this feature when they discontinued the Variax basses. Have any of you Variax 700 & 705 bass owners tried alternative tunings manually? Say a semi-tone down. I'd like to know how the piezo's perform with lighter tension on them. TD Quote Link to comment Share on other sites More sharing options...
