titchyblackcat Posted July 4, 2014 Share Posted July 4, 2014 I've an old Pod 2 with 2.1 software and seem to have trouble with the latest Line 6 Edit being a bit haphazard. (Comms and Settings) Is there a recommended old version of Line 6 Edit that may be better for this old Pod ? Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 7, 2014 Share Posted July 7, 2014 Hey There, You are going to have to provide more info if you want someone to help you. Trouble? such as? Comms and settings? You should list your OS and what type of midi/usb cable. -B Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted July 8, 2014 Author Share Posted July 8, 2014 Sorry . The pc is running xp and is connected to the Pod 2.1 with 3m MIDI cables. This goes to an M-Audio 2496 card in the pc. The pc just hangs (freezes) for a minutes or 2 sometimes or. just hags until i use taskmanager to exit I've tried Line 6 edit 3.06 and 3,04 so far but they seem to do the same. Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted July 8, 2014 Author Share Posted July 8, 2014 Seems to be a bit quicker with Line6 Edit 3.0 but won't exit without Taskmanager. Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 8, 2014 Share Posted July 8, 2014 With WinXP I just plug in a MAudio Uno and the latest version L6E just fires up. It may be that the USB interface is causing the problems you are experiencing. Wish I could be of more help but I have no experience with that PC Card. If you could borrow a pair of cables you could try connecting it directly and see if "its all good". -B Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted July 9, 2014 Author Share Posted July 9, 2014 Pod 2.1 goes to the midi on the sound card there's no usb. On the M-Audio sound card there are 2 midi connectors so i think the connectivity is OK. Also this set up works fine with my Tonelab so i think the midi link is OK Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 9, 2014 Share Posted July 9, 2014 Hmmm I am at a loss then - perhaps you could try it on a friend's computer that has a direct usb port. Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted July 9, 2014 Share Posted July 9, 2014 update java 1 Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted July 9, 2014 Author Share Posted July 9, 2014 OK Thanks i'll update Java. As the machine isn't on the internet it could be an old version on there. I'll let you know in a couple of days as i don't have a lot of time at the moment. Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted July 12, 2014 Author Share Posted July 12, 2014 It was Java. Thanks for the info' For anyone else that reads this what i did was. Uninstall both Line 6 Edit and Java. Up load latest version of Java first followed by Line 6 Edit. This sorted my comm's out fine. Once again thanks for the help guys. :) Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 14, 2014 Share Posted July 14, 2014 Cool - never even thought about java. Mental note taken! Excellent Toneman! -B Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted July 17, 2014 Share Posted July 17, 2014 it was a big issue way back in the xt era. some dude named supersupro even wrote an app to make edit work before line6 fixed the problem. Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 17, 2014 Share Posted July 17, 2014 Man priceless info too - the archives are kind of hard to dig specific info out of sometimes. Its awesome you guys stick here to pass this stuff along. ThanX! -B Quote Link to comment Share on other sites More sharing options...
