Sign in to follow this
altonabeach
Dual output guitar
I've got a Dual Output guitar (Magnetic and Piezo Out).
I'd like to know if I could use the Aux in to connect the piezo Out, and use the main guit in for Magnetic pick up.
Also, has the Aux in got access to effects?
Regards
Altonabeach
If you had the right adapters you could try going into the aux in, but it would be going directly to the power amp. I suspect it wouldn't sound like you want. Also, the level from your guitar might be too low for that jack. I kind of already answered your second question, but no, the aux in isn't processed through the effects and amp models.
I guess I could connect the Piezo out to  a little Mixer with effects to twick the tone correctly.
This way I would have a Clean acoustic sound into Aux, and could be mixed with the main guitar input....
I'll try this configuration and I'll let you know how it sounds...
