nguyen232 Posted July 24, 2014 Share Posted July 24, 2014 Hi Guys, I want to build a 1*12 cabinet for my Spider Valve MKII 112. I want to know what speaker should i use for this. I red my amp is using 12" speaker Celestion Vintage. On the web I see this 2 Celestion speaker Celestion Vintage 30 - 8 Ohm and 16 Ohm for both the spec says 60w Should I am wondering if i choose this speaker as well for my cab ? thanks Quote Link to comment Share on other sites More sharing options...
radatats Posted July 24, 2014 Share Posted July 24, 2014 ok so you CANNOT use a 16 ohm speaker, you have to go with the 8 ohm no matter what brand or model you choose. you can stick with the Celestion Vintage or you could get creative and use a different speaker that will complement the stock internal Celestion but with a different tone. Do your research, there are lots to choose from, Celestion, Eminence, and one of my favorites Warehouse Speakers... http://celestion.com/ http://www.eminence.com/ http://wgs4.com/ Quote Link to comment Share on other sites More sharing options...
nguyen232 Posted July 25, 2014 Author Share Posted July 25, 2014 Thanks ! Quote Link to comment Share on other sites More sharing options...
cgtrox Posted August 24, 2014 Share Posted August 24, 2014 You can also build a 2x12 cab using two 16 ohm speakers wired in parallel to give you an 8 ohm load. I use a sealed 2x12 Marshall with G12T-75's and my open backed combo on top. The sealed cab gives you the extra thump missing from the combo. We call it a pyramid of doom! A good combination is using the V30 from the SV and a Celestion G12H. cgtrox B) 1 Quote Link to comment Share on other sites More sharing options...
