schrismer Posted June 8, 2013 Share Posted June 8, 2013 hey there..... I'm using an HDpro in a Effects loop of a Mesa MIV.....using only "after" amp effects....I have an "effect loop" Block at the front of the chain (in the HDPro) and then delays, verbs and so on after the mixer.... anyway.... does anyone know if there is a trick of get spill over of the delay's and reverbs after a preset change or once you turn the delay off... having it spill over ? thanks Steve Quote Link to comment Share on other sites More sharing options...
schrismer Posted June 9, 2013 Author Share Posted June 9, 2013 Yes... there is a "trails" setting... and I have it on....?? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted June 9, 2013 Share Posted June 9, 2013 the trails option only allows trails from the effects loop on the pod... it basically mutes the loop in will accepting the loop return... so unless you want trails from non-pod gadgets in the loop that setting won't help. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 9, 2013 Share Posted June 9, 2013 Also, the TRAILS setting only applies within a preset so that, for instance, delay trails will continue when the Delay FX is turned off. Even with TRAILS ON the trails will be cut off when you switch presets. Quote Link to comment Share on other sites More sharing options...
