scias23 Posted August 11, 2014 Share Posted August 11, 2014 I want to hook a M9 to my POD HD via MIDI to control the tap tempo of M9 via POD HD tap button. However I don't want the POD HD to send MIDI program change to M9. I basically have one delay setting across all my patches so the M9 has my delay setting. Thoughts anyone? Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted August 11, 2014 Share Posted August 11, 2014 There was a couple of discussions about integrating the two before http://line6.com/supportarchivenew/thread/89945 http://uk.line6.com/supportarchivenew/thread/55337 The good news is that for what you want you are OK. The HD500 doesn't send a tempo change that the M9 would recognise, but you can program the tap tempo button: From phil_m in the second of those threads: "The M9 can receive MIDI clock, but not send it. The HD500 does neither. Anyway, though, you can assign the correct CC# to the tap tempo switch on the HD500 and send that to the M9. This would sync the M9 whenever you actually tap a tempo on the HD500. CC#64 is what you need to send from the HD500 to the M9. The HD500 Advanced Guide explains how to do this on page B-4." So set the M9 to listen to a different MIDI channel to the global channel on the HD (so that program change are ignored), then program the hd tap-tempo to sent CC#64 on the channel that the M9 listens to. The bad news is that you will need to set this up separately for every HD patch. Quote Link to comment Share on other sites More sharing options...
scias23 Posted August 12, 2014 Author Share Posted August 12, 2014 There was a couple of discussions about integrating the two before http://line6.com/supportarchivenew/thread/89945 http://uk.line6.com/supportarchivenew/thread/55337 The good news is that for what you want you are OK. The HD500 doesn't send a tempo change that the M9 would recognise, but you can program the tap tempo button: From phil_m in the second of those threads: "The M9 can receive MIDI clock, but not send it. The HD500 does neither. Anyway, though, you can assign the correct CC# to the tap tempo switch on the HD500 and send that to the M9. This would sync the M9 whenever you actually tap a tempo on the HD500. CC#64 is what you need to send from the HD500 to the M9. The HD500 Advanced Guide explains how to do this on page B-4." So set the M9 to listen to a different MIDI channel to the global channel on the HD (so that program change are ignored), then program the hd tap-tempo to sent CC#64 on the channel that the M9 listens to. The bad news is that you will need to set this up separately for every HD patch. I already read those threads. What I need is a solution that won't require additional equipment. It seems like the PoD HD always sends program change message.. Quote Link to comment Share on other sites More sharing options...
watchbr Posted August 13, 2014 Share Posted August 13, 2014 That's why you change the MIDI channel on the M9 - so it won't respond to program change messages from the HD. This solution requires no extra equipment. Quote Link to comment Share on other sites More sharing options...
scias23 Posted August 13, 2014 Author Share Posted August 13, 2014 That's why you change the MIDI channel on the M9 - so it won't respond to program change messages from the HD. This solution requires no extra equipment. Thanks for clarifying! Quote Link to comment Share on other sites More sharing options...
