357mag Posted September 13, 2014 Share Posted September 13, 2014 I'm playing a Japanese Strat with Duncan YJM Furys into my POD HD Pro X. I'm using the Brt J-45 Head with a Celestion Greenback 25 cabinet. Currently using a 409 Dynamic microphone. I have the Low Cut Cab Parameter set to 50 Hz. I like my sound but my complaint is it's dark. I mean kinda on the muffled, bassy side. I've experimented with the Parametric and Graphic EQ but it still seems to sound too dark. If I could keep the basic sound the same but just remove some of the bassiness and add some sparkle and mids/treble that's what I'm looking for. But I haven't been able to do it yet. Are there certain Equalizers and certain frequencies I should be working with? I like the sound of Greenbacks but they sure sound like a dark speaker to me. Can you help remove some of the darkness and bring me into the light? Quote Link to comment Share on other sites More sharing options...
stumblinman Posted September 13, 2014 Share Posted September 13, 2014 I'm a big fan of the blackbacks... It's the cab I use almost exclusively. I also use it live into a DT25 though, so it's apples and oranges. Checking your input Z value may help as well.. Is it set to auto? Experiment with different values. It's amazing what a difference it makes. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted September 14, 2014 Share Posted September 14, 2014 I would suggest increasing the Low Cut from 50hz up to 80 or 100. Also the Input Z (Impedance) can make a difference. Instead of leaving it on Auto try changing it to different numbers. Larger number are brighter sounding. Quote Link to comment Share on other sites More sharing options...
