Mynameismatt Posted September 16, 2014 Share Posted September 16, 2014 Iwant to know peoples experiences using pod hd with variax via digital cable and putting external drive pedals in the effect loop. Im thinking my signal chain would go something like this... Variax > POD in > Wah > Effects loop send > JHS Morning Glory > Tube Screamer > Effect loop return > Amp Model > Delay > Pod Output Would it work well ? anyone doing it? I don't like the internal drives in the POD but want the versatility on the JTV connected via VDI. Quote Link to comment Share on other sites More sharing options...
malnack Posted September 16, 2014 Share Posted September 16, 2014 I use an Electro-Harmonix Soul Food as you describe. It is in the effects loop of the HD500. It made a huge improvement to my rig. My signal is passed to the DT-25 via L6 Link cable. Quote Link to comment Share on other sites More sharing options...
Mynameismatt Posted September 16, 2014 Author Share Posted September 16, 2014 I use a line6 M5 in the loop already and works fine apart from having to drop the send level of the effects loop as it clips the M5. I just wonder if there will be issues with drive pedals Matt Quote Link to comment Share on other sites More sharing options...
malnack Posted September 16, 2014 Share Posted September 16, 2014 I haven't had any issues. The only issue was getting the Soul Food level set so that when I engaged it I didn't get a huge volume boost. It varies from room to room that we play in so during sound check I engage it and then adjust it so that it is only a slight boost over the clean signal. Quote Link to comment Share on other sites More sharing options...
Unorthodoxic Posted September 16, 2014 Share Posted September 16, 2014 I have things set up a little differently to what you suggest. I go from the JTV into HD500x via VDI (I never use the Variax input on the HD500x it's connected only to power the JTV and change presets via the footswitchs/patch changes). The 1/4" jack output from the JTV then goes into a DI box (you need a ground lift when using both outputs from a JTV otherwise you get ground loop interference), out the DI box and into an EHX Tortion overdrive pedal, which then goes out into the guitar in on the HD500x. JTV ----via VDI----> HD500x JTV ----via 1/4" jack----> DI Box -> Overdrive Pedal -> HD500x It works well and really gives me a nice signal going into the HD500x. Then I use the FX loop to place a Strymon Big Sky in there. I do plan on moving it so it takes the output from the HD500x, but then that would render the HD500x's looper useless. When I get a Strymon Timeline I'll definitely have it following the HD500x then, that will free up loads of DSP for the HD500x. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted September 17, 2014 Share Posted September 17, 2014 And I thought I had enough problems not tripping over a single cable (VDI)! Quote Link to comment Share on other sites More sharing options...
Mynameismatt Posted September 17, 2014 Author Share Posted September 17, 2014 That's a genius work around Rewold but its a shame you have to use a DI and don't get the beneift of the clean VDI signal. Quote Link to comment Share on other sites More sharing options...
Unorthodoxic Posted September 17, 2014 Share Posted September 17, 2014 That's a genius work around Rewold but its a shame you have to use a DI and don't get the beneift of the clean VDI signal. I did things that way because I have other things in the FX loop. If I do get another looper I can put at the end of everything then I may very well move the overdrive to the FX loop and delays and reverbs after the HD500x. If I did things that way I could then just use the VDI connection. Quote Link to comment Share on other sites More sharing options...
Mynameismatt Posted September 18, 2014 Author Share Posted September 18, 2014 Thats what I'm thinking of doing - if i can find a jtv for the right price Quote Link to comment Share on other sites More sharing options...
