Magnetic & Acoustic: Pedal to pan between the two?
swipesy
Hello all.  I'm considering getting either an X3L or an HD500/HD500X.  I do have a question though, and I wasn't able to find an answer after searching for quite a while.
Q:  Can either the X3L or HD500/X do the following?
1.  Set up the magnetic guitar sounds on line 1.
2.  Set up the acoustic sound on line 2.
3.  Set up an expression pedal to pan between the two lines.
I typically use only four effects in any given chain, and never more than three together:  Chorus, reverb, delay and flanger.  For acoustic I simply use EQ without cab emulation.  Currently I use two separate rigs for magnetic and acoustic sounds and would very much like to combine the two if at all possible.
If you need any further information just ask.
Thanks for the help!
If you mean switch between the 2 lines
i think you need to do:
On line 1 :  pedal closed and select the volume on the screen  and double clik (on-off button) to edit     button1 - 0%   button 2 - 100%
on line 2 :  pedal open and select the volume on the screen  and double clik (on-off button) to edit    button1 - 100%  button 2 - 0%
now in theory if you use your expression pedal (it works on FBV's)  you switch between the 2 line's
Hope it help you
