JeffersteinVS Posted September 19, 2014 Share Posted September 19, 2014 Using the m20d with stagescape speakers via Line 6 link. can i use one of the monitor out ports to send the mono f.o.h mix? Quote Link to comment Share on other sites More sharing options...
dboomer Posted September 19, 2014 Share Posted September 19, 2014 I think the answer to your question is yes. But I'm not sure I fully understand what you expect to do. Can you I elaborate further? Quote Link to comment Share on other sites More sharing options...
JeffersteinVS Posted September 19, 2014 Author Share Posted September 19, 2014 what is the best way to link the f.o.h mix to that monitor aux send? so when i adjust f.o.h same changes apply to that monitor out Quote Link to comment Share on other sites More sharing options...
eklynx Posted September 19, 2014 Share Posted September 19, 2014 Set all sends to that specific aux send at unity and post fader (linked) and that should do what you are asking for Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted September 19, 2014 Share Posted September 19, 2014 You can't route the main mix to an aux (monitor) output. The solution suggested by eklynx will work, because as you adjust each channel the linked aux send will follow. But any change to the main fader won't change the overall output level of the aux; you'll have to do that separately. There are tricks you can do with external patches; I've done things like this in the past. For example, split the main LR outs with Y-cables. Run those to your FOH amplifier and also to two spare Line input channels. Route those channels only to the aux you want, UNlinked. Do not route them to the mains at all otherwise you'll a have feedback loop. (This is a little tricky because you have to guarantee you never raise the fader on those channels.) Set the appropriate aux-send level in those channels. Now when you adjust the main mix (and its level), you get a corresponding level change in the aux output. Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted September 20, 2014 Share Posted September 20, 2014 You can assign any speaker to any bus in the L6Link settings. If you want a speaker to play the main mix just assign L, R or L+R to the speaker in the L6Link settings. Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted September 20, 2014 Share Posted September 20, 2014 Neat. Those StageSource speakers have a few nice tricks up their sleeves. (Do they actually have sleeves?) Quote Link to comment Share on other sites More sharing options...
JeffersteinVS Posted September 21, 2014 Author Share Posted September 21, 2014 what i ended up doing to not utilize a aux send was I made up a 1/4 to xlr male cable and used the headphone jack on the m20d mixer to feed a mono left signal of the main mix to the house P.A mixer so they could broadcast the band to the outside speakers. worked well and gave me the ability to use all 4 monitor mixs for monitors. Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted September 21, 2014 Share Posted September 21, 2014 That works too! I noticed in the block diagram that the headphone jack mirrors the main output if nothing is soloed. Quote Link to comment Share on other sites More sharing options...
