Jerkon Posted September 26, 2014 Share Posted September 26, 2014 Today I did the update of Flash Memory v2.10 to v2.32 and the sound of POD HD 500 has changed a lot and became very bad.After the update, I did the "Global Reseting" then recalibrated the pedal and did the restoration of my "Bundle"So when I connected the POD HD500 into an amp, I realized that the sound was horrible, very acute and with no required modulations, including the preset sounds.So what do I do?Rollback the Flash Memory v2.10 or what? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted September 27, 2014 Share Posted September 27, 2014 Have you checked to see if the global output is the same as before? i.e. Studio direct, combo, etc. Quote Link to comment Share on other sites More sharing options...
Jerkon Posted September 27, 2014 Author Share Posted September 27, 2014 I normally use Studio Direct and I not checked this. Quote Link to comment Share on other sites More sharing options...
bvaladez74 Posted September 27, 2014 Share Posted September 27, 2014 Revert back to the prior version. You don't have to move up...especially if the bug fixes don't apply to you. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted September 27, 2014 Share Posted September 27, 2014 Also check your input Impedance setting. 1 Quote Link to comment Share on other sites More sharing options...
Crusty_Old_Rocker Posted September 28, 2014 Share Posted September 28, 2014 You'll most likely find that it's the input and output settings. Just double check them. Cheers, Crusty Quote Link to comment Share on other sites More sharing options...
