rybones1311 Posted June 16, 2013 Share Posted June 16, 2013 I have a 75 watt Spider 2 head. Recently, the volume on my line 6 spider 2 head has volume issues. I will be playing my guitar then the volume drops drastically low. I would say 85%. I have tried factory resets multiple times. I have also tried to reprogram the channels with volume settings, yet nothing has worked. The volume still drops out on me. Any idea on what this could be? Thank you. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 17, 2013 Share Posted June 17, 2013 I would suspect a faulty component (like a power capacitor) or solder joint - once it heats up, the fault happens. Quote Link to comment Share on other sites More sharing options...
Natedog_37 Posted June 17, 2013 Share Posted June 17, 2013 Also been read that with high volume these digital knobs will drop down and turn the volume down. Check to see if at high volume if the master volume is not dropping due to all the shaking. If so there are a couple of youTube videos I have seen about adding washers to tighten up the knob. Quote Link to comment Share on other sites More sharing options...
rybones1311 Posted June 18, 2013 Author Share Posted June 18, 2013 I think if in a few more days I can't figure it out (I've even had it apart twice and cleaned it out) it's hitting the trash. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 18, 2013 Share Posted June 18, 2013 Also been read that with high volume these digital knobs will drop down and turn the volume down. Check to see if at high volume if the master volume is not dropping due to all the shaking. If so there are a couple of youTube videos I have seen about adding washers to tighten up the knob. The 'volume drop' issue can indeed happen from a moving channel knob (from vibration) when the knob is turned lower than what the patch preset is set at, but I don't think this is the problem in this case. Quote Link to comment Share on other sites More sharing options...
