Feb 9, 2012 2:29 PM
Dual Cab Tones - lil help...?
Like (0)
Lately on most of my patches I use "dual cabs" - I set up a dual amp patch, and use the same amp for both channels with identical settings, but use different cab/mic combinations for each channel. I will adjust the amp/channel volume knob to balance the volume of each channel so neither dominates the other, and you find the sweet spot where they complement each other. I also pan both channels to dead center in the mixer, so I get one thick mono tone.
Here's a list of the combinations that have worked well for me:
It takes a while to experiment and find new combos that work well. I was hoping some community members here might feel a bit adventurous and help find combinations that work well together. Post whatever you find!
Thanks.
I often use a Fender Twin with the Park 75. I'm mainly after the big Plexi Marshall sound but then I dial in the clean Fender sound until it gives my tone a bit more clarity. Usually about a 60% Park 40% Fender gets me there. Though I get frustrated too much by the DSP Limit that I have really thrown in the towel on developing good Dual Patches. It's a real shame because what you can do with the HD vs the X3 is some respects is so much more but the DSP Limit really hurts. Ultimately if I could wave a magic wand, I would have my Dual Amp patch set so I could assign F1~4 for Effects for Amp 1, F4~8 for Amp 2, Volume/Wah, plug an extra expression pedal and that would control the mixer so I could or Amp Master Volumes so I could blend the two amps on the fly.
Now that I typed all this I looked back at your post and see I'm a little off topic, but hey I typed all this, and got to vent a little! So we'll leave it at that.
it's all good! topics are meant to be broken!
Anyhoo, here's a little advice with your dsp issue: Instead of using the Fender on one channel, select no amp instead. Then put a compressor and EQ in that channel. You lose 2 effect blocks, but you'll use less DSP, so you should be able to use all 6 remaining blocks, instead of capping out at 4 or 5 otherwise.
Piggybacking a bit off Dave's post, I primarily use the dual tread amps, and set one at about 60% gain and the other at 30% in order to get a nice blend of crunch and moderate gain. I think varying the eq's on them fills in the frequencies nicely.
