HD500X HDPRO X - Latency specs needed
panca
Hello,
I'd wish to know in-out processing latency for the "X" models (is it different between 500X and PRO X?), with FX loop disabled AND activated (double AD-DA conversion).
Thanks
m.p.
Should still be able to get the information....probably have to start a suppor ticket, email support directly, wait a day or two, not get an actual answer....good luck. everybody else who has technical questions just tests everything themselves since the company has no interest in the boards....
Why do you need to know the latencies ?
I thought I remembered reading on some post somewhere it was around 7ms.  Don't know if that was measured using the FX loop too.  I think the AXEFX was a couple ms faster.
I can't tell any latency while playing.
The X3 Live is about 1.5 ms with all blocks bypassed. The HD desktop about the same.
It is very simple to mesure: split a signal, one half directly in a soundcard input, the other half thru the POD in the other input. Send a signal and verify time difference.
7 ms is a ridiculously long time for a HW machine,,,it is probably when is hooked to the computer as a USB soundcard.
The new HD Xs being slightly different, I'd wish to be sure about it.
thanks
m.
