HD500X as a midi-in interface?
hd500x midi audio driver mac
Best Answer phil_m , 06 July 2014 - 05:10 PM
The MIDI jacks aren't seen by the driver, so there's no way to use the HD500X as a MIDI interface for another device like you're describing.
Go to the full post
3 replies to this topic
#1 dakomus
dakomus
  • 2 posts
Posted 06 July 2014 - 02:00 PM
Just bought an HD500X and was under the impression that it could export the Midi-in port to my software.
I haven't been able to do that and then I realized that it could be used exclusively to control patch changes
etc. for the POD. So my question is - is it possible to setup so midi messages appearing on midi in are seen
by the driver? (My use case is that I have a midi keyboard but no (reliable) midi input for the computer and I
would like to use midi to control a software piano (Steinberg, The grand)) Anyone can offer some help?
I'm using a fairly recent Macbook Pro retina display.
Kind regards,
      /Daniel
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9061 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 06 July 2014 - 05:10 PM   Best Answer
#3 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1220 posts
  • LocationUK
  • Registered Products:6
Posted 07 July 2014 - 03:22 AM
Simplest option it to use a universal USB MIDI interface - dirt cheap.  I have had some success on a PC and it says MacOS is supported:
http://www.amazon.co...t/dp/B000XRI3CC
I was using it to trigger VSTi.  But the set-up does get a bit messy, and more prone to failure live.  My solution was to buy a better keyboard (Motif XF) that could by itself make all of the sounds I was getting from VSTi... No Computer or MIDI Interface required: much simpler.
I will admit that a MIDI interface for a few £ is very cheap, and a Motif is not (even used), but the laptop isn't that cheap either and is not necessarily designed for life on the stage.
#4 dakomus
dakomus
  • 2 posts
Posted 09 July 2014 - 08:52 AM
Thanks for the info, Phil. Seems I need to look elsewhere for my MIDI interface need.
@Rewolf:
Checked out the link and that was crazy cheap compared to what I've seen before. However some of the user reviews said
it didn't manage to process polyphonic chords quickly enough so I think it's best to pass on that specific model. I'll just keep looking. Thanks for the advice, though.
Also tagged with one or more of these keywords: hd500x, midi, audio driver, mac
