http://line6.com/legacy/images/Floorboard.jpg
Line 6 Floorboard:
ONLY Compatible with: AX212, 1st Generation POD/Bass POD, POD Pro (labeled "Pedal" above Cat 5 Connector"), 1st Generation of Spider (Red Faced) Flextone 1, Flextone II, Flextone HD.
http://line6.com/legacy/images/FB4.jpg
FB4:
ONLY Compatible with: AX212, 1st Generation POD/Bass POD (labeled "Pedal" above Cat 5 Connector"), 1st Generation of Spider (Red Faced) Flextone 1, Flextone II, Flextone HD.
http://line6.com/legacy/images/fbv4_5803n.jpg
FBV4:
Works With: Flextone III, Vetta, Vetta II, HD147, Duoverb, PODxt, PODxt Pro, Bass PODxt, and Bass PODxt Pro Spider II, Spider III, Spider Jam, Spider IV, POD XT,POD X3, POD X3 Pro, POD XT Pro, AMPLIFi series, Firehawk 1500.
Does NOT Work with: Ax212, Flextone I, II or HD, POD 2.0, POD Pro, Bass POD, Bass POD Pro and
Spider 1
FBV or FBX Longboard:
http://line6.com/footcontrollers/fbv.html
Works With: Flextone III, Vetta, Vetta II, HD147, Duoverb, PODxt, PODxt Pro, Bass PODxt, POD X3, POD X3 Pro, Bass PODxt Pro Spider II, Spider III, Spider Jam.
NOT compatible with Ax212, Flextone I, II or HD, POD Pro, Bass POD, Bass POD Pro and 1st Generation (Red Faced) Spider Spider IV, Spider Valve, Spider Valve MKII, POD HD
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
*FBV is not compatible with Spider II 15 or Spider III 15.
FBV Express MK1(Does not have USB Port):
http://line6.com/footcontrollers/fbvexpress.html
Compatible With: Spider Valve, Spider Valve MKII, Spider II, Spider III, Spider Jam, Spider IV, Flextone III, Vetta, Vetta II, HD147, POD 2.0, POD XT, POD XT Pro, POD X3, POD X3 Pro, Bass POD XT, LowDown, POD HD Desktop/HD Pro
NOT compatible with: Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider 1
*FBV Express is not compatible with with Spider II 15 or Spider III 15.
**FBV Express is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
****FBV Express Mark 1 is not officially supported for Spider V, but it will not damage the amp.
FBV Shortboard MK1 (Does Not Have USB Port):
http://line6.com/footcontrollers/fbvshortboard.html
NOT compatible with: Ax212, Flextone I, II or HD, POD Pro, Bass POD, Bass POD Pro and Spider 1
*FBV Shortboard is not compatible with with Spider II 15 or Spider III 15.
**FBV Shortboard is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
****FBV Shortboard Mark 1 is not officially supported for Spider V, but it will not damage the amp.
FBV2 (Does Not Have USB Port)
Compatible With: Spider Valve, Spider Valve MKII, Spider II, Spider III, Spider Jam, Spider IV, Spider V, Flextone III, Vetta, Vetta II, HD147, POD 2.0, POD XT, POD XT Pro, Bass POD XT
NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider 1, POD HD Series, Lowdown, AMPLIFi series,
*FBV2 is not compatible with Spider II 15 or Spider III 15, and Spider V 20.
**FBV2 is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
FBV Express MKII:
http://line6.com/footcontrollers/fbvexpressmkii.html
Compatible With: Spider Valve, Spider Valve MKII, Spider II, Spider III, Spider Jam, Spider IV, Spider V, Flextone III, Vetta, Vetta II, HD147, POD 2.0, POD XT, POD XT Pro, POD X3, POD X3 Pro, Bass POD XT, LowDown, POD HD series, Amplifi series, Firehawk 1500
NOT compatible with: Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider 1, Spider V 20
*FBV Express MKII is not compatible with Spider II 15 or Spider III 15.
**FBV Express MKII is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
FBV Shortboard MKII:
http://line6.com/footcontrollers/fbvshortboardmkii.html
Compatible With: Spider Valve, Spider Valve MKII, Spider II, Spider III, Spider Jam, Spider IV, Spider V, Flextone IIi, Vetta, Vetta II, HD147, POD 2.0, POD XT, POD XT Pro, POD X3, POD X3 Pro, Bass POD XT, LowDown, POD HD series, Amplifi series. Firehawk 1500
*FBV Shortboard MKII is not compatible with Spider II 15 or Spider III 15.
**FBV Shortboard MKII is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
FBV 3
Compatible With: Firehawk 1500, Amplifi series, POD HD, POD HD Pro, POD HD Pro X, Spider V, Spider IV series, Spider Valve MKII, Spider III HD150, Spider III HD75. Spider III 150, Spider III 120, Spider III 75, Spider Jam
NOTE: When using the FBV 3 with the Spider IV and Spider Valve MKII series, the FBV 3 cannot be used as the interface to update or edit the amps with your computer. The FBV MKII pedals (Shortboard and Express) must be used for that functionality.
Assignable color LEDs available for use with Firehawk 1500 and Spider V only. LEDs are red when FBV 3 is used with other Line 6 products.
Not Compatible With: Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider 1, Spider V 20
Note: All other gear not listed as compatible will have limited functionality and usage is not recommended. The Shortboard MKII will have better compatibility with legacy products.
Other Helpful Links:
Manuals:
http://line6.com/support/manuals/
(Note: when using our amps the guide to using your foot controller is generally in the amp's manual under the Using Your Feet section.)
Pedal Compatibility Chart for Older Products:
http://line6.com/footcontrollers/compatibility.html
