If there are intermittent drop-outs or disconnect with the Helix Stadium software when you're connected to a known stable WiFi network. It's a good idea to check your WiFi router to see if it matches the standards supported.
You can look up your WiFi router model online, and see if it matches one of the supported options from the manual:
https://manuals.line6.com/en/helix-stadium/live/wifi-bluetooth-and-ethernet-connectivity
The following Wi-Fi IEEE standards are supported:
802.11b, 2.4GHz
802.11a, 5GHz
802.11g, 2.4GHz
802.11n, 2.4GHz, 5GHz (Wi-Fi 4)
802.11ac, 5GHz (Wi-Fi 5)
If it's not a match with one of these supported formats, then you may need to consider an alternative router, or upgrading your router if its outdated.
Another work-around would be connecting through the Ethernet to USB-A adapter that's mentioned in the manual. (see above link)
