jameshoy
Members-
6 -
Everything posted by jameshoy
I use the Truetone CS6 power supply to run my HX Effects and a Swollen Pickle. You’ll want to make sure you are not drawing more current than the CS6 can supply. The HXFX and on low current draw pedal is all I need to power for this pedal board. You’ll use a standard power cable plugged into the reverse polarity adapter (red) plugged into the L6 barrel size adapter (green). All cables and adapters are included when purchased new. Only issue I’ve encountered was when I accidentally left my HXFX on overnight. I think the power supply got too hot and turned itself off. Beyond that, should be fine for rehearsals and gigs. Just turn your stuff off.
Little bit of thread necromancy. What are you finding lacking? What wattage is that poweramp running? I'm wondering if you need more power. Not so much for volume but for accurately reproducing low frequency content. Bass frequencies gobble up wattage. It's also possible that the output impedance of the LT isn't jiving with the input sensitivity of the poweramp. Might need to fuss with the output impedence in your global settings to get the LT to drive that poweramp a bit more. Line level is going have more umph than instrument or mic level. Page 65 of the Rack user manual details Inputs and Outputs (as an LT user, your mileage may vary) Also check and play with the "Gate" and "Guitar In-Z" settings on the the input block of your signal path. From page 26 of the Helix Rack Owners manual (as an LT user, your mileage may vary)..... Lately my band has been recording and part of that process is tone finding. Were are opting on using Helix solely going to our interfaces and directly to Ableton Live. No mic'ing physical cabs. So far the SVT4Pro is my favorite of the stock Helix Amp Models and I've been building my tone around that. I'm looking for a pretty aggressive rock tone so I crank the Mid Frequency control all the way up and give the Midrange control a bit of a bump. I'm also using a Muff bass fuzz (actual pedal) in an FX loop and running that with a wet dry mix on the FX Loop block. I'm in love with the tones I'm achieving (not even getting into what I'm doing with Signal Path 2, the built in effects, using a guitar preamp on that path and mixing in the Hologram Electronics Microcosm in an FX Loop and doing an overall wet/dry mix). I'm less than enthused on the stock Helix Cab Emulations. They are all just wimpy sounding lacking any real clarity. So I researched and downloaded the Celestion Pulse 10 and Pulse 15 IR player packs. These IRs definitely pulled the wet blanket off my tone. I'm achieving a pretty big clear sound. The gloves really came off when I starting messing with the Horn IRs in the 4x10 and 1x15 IR folders in those Celestion packs. Lovely pick attack and more high end content on my fuzz tone. Currently I'm stacking a 410 plectrum aggressive (on path 1A) with a 115 horn IR on a parallel path (1B). For live settings I have yet to get a poweramp to drive my fridge cab but am pretty much settled on the Matrix GT1600fx. This is a stereo poweramp with 800watts at 4ohms per channel. I could theoretically efficiently power two Ampeg 810e Cabs if I wanted too (it's possible). I will be building a collection of Bass cabs (an array of smaller cabs, looking at the Orange single 12 cabs or the Avatar 126sb Cabs) and maybe some FRFR cabs (the Tech21 Power Engine 200s look suitable to reproduce Hi End Content) to deal with any live setting from small house shows/bar gigs with little or no PA, to larger venues with much more robust PA systems. We will be investing in IEMs as well. Again, pushing that much power is less about actual decibels and more about accurately reproducing clear tight low end content and giving the stage some feel. In these cases I'll run a path that has Speaker/Cab IRs for FOH and FRFR cabs and no IRs for actual bass cabs. Prior to switching to Rack (My first foray into Helix is the HX Effects which I still have and love); I was using my SVT-CL (USA made, SLM era amp) running in 4 cable method pushing an Ampeg 810e. This setup didn't require any of the Amp models or Cab emulations. I was using Rack mainly for the effects, the effects loops to integrate analog pedals as well as the SVTs preamp, and to design signal flows. I was able to dial in some massive tones with this setup but 4CM is honestly a bit too clunky in wiring up and can introduce failure points, which is why I'm going the Helix Rack driving a poweramp driving some Bass cabs route. Moral of the story is that you can achieve amazing bass tones with Helix. There's a lot of options and there may be a bit of a learning curve but stick to it and you'll get there.
Hey all, I'm relatively new to MIDI and wanted to share some settings and menu dives that I've encountered in my research that got Helix Rack and the Hologram Electronics Microcosm talking to one another seamlessly and behaving the way that I intend it too. Looking over the internet, it's pretty easy to find direction on how to get everything set up but there isn't anything Helix Rack/Microcosm specific so I thought it would be handy to have all the information I've uncovered in one place to save on time for other Helix/Microcosm users. While this may be intuitive for more seasoned MIDI users, this took a moment for me to wrap my mind around. I'm by no means a MIDI expert and am only scratching the surface here. YMMV and if anyone wants to plug any holes, correct any mistakes and expand; I'm game.. You'll want a copy of your user manual for both Helix Rack and Microcosm. User Manuals Helix Rack: https://line6.com/data/6/0a020a3f63bf5fb6a4a7df95a/application/pdf/Helix Rack and Control 3.0 Owner's Manual - Rev D - English .pdf Hologram Electronics Microcosm: https://b82316c2-7eca-4286-9569-a4da8097c930.filesusr.com/ugd/74428b_c4e6e20555914198bdb59c12f9a9e4d4.pdf What I found easier for me is, rather than using HX Edit on a computer connected to Rack, use the Human Machine Interface (HMI, ie the front panel of Helix Rack) to navigate all the settings and save when you are finished. Let's dive right in. Connections I/O: The first thing you'll want to do is fairly obvious. Get everything hooked up. For my purposes I use 5 Pin MIDI Cable going directly from my audio interface to Helix Rack's MIDI input. I then connect another 5 Pin MIDI cable from Helix Rack's Out/Thru to the MIDI input on Microcosm. My understanding is that you can also accomplish some of these connections via USB but I've not explored these settings or connections. Beyond that I have Microcosm's audio routed into one of the effects loops on Helix Rack and have been experimenting with wet/dry (etc) signal flows. Global Settings: The first thing I wanted to do was be able to control tempo on Helix Rack via Ableton and then send that MIDI clock to Microcosm via Helix Rack. The thinking is that while recording, I'll be using a click and can have delays and other time based effects both internally on Rack as well as the delays and loops on Microcosm sync to click. This will also help when my guitarist (also a Rack user) is using delays or other time based effects and we will be more in lockstep with one another. Everything is slaved off of one master MIDI Clock. The hope is that this will have utility further down the road as we will be using Ableton to control clicks, backing tracks and samples for live performances. These settings are relatively straight forward. To control Helix Rack via an external Midi Clock, you'll want to navigate Menu > Global Settings > MIDI/Tempo and set "Receive MIDI Clock" to "MIDI". This allows Helix Rack to sense the click coming from the DAW (you'll have to play with the MIDI sync settings in whatever DAW you use to get Helix Rack and the DAW to "see" one another). You will know when Helix Rack syncs with an external clock as the Tap Tempo Switch on your Helix Foot Controller (if available) will switch from Red to Blue. My experiences is that Helix Rack only receives the clock from Ableton when you select Play or Record in Session or Arrangement mode of Ableton. To Send MIDI Clock to Microcosm via Helix Rack you'll want to navigate Menu > Global Settings > MIDI/Tempo and change "Send MIDI Clock" to "MIDI". "When [Microcosm] receives a MIDI Start Message, the pedal [Microcosm] will switch from its internal clock to the external clock signal. Upon receiving a MIDI Stop message, the pedal [Microcosm] will revert back to its internal clock" (Microcosm User Manual .pdf, p. 21 or p. 41 of the physical manual). My experience is that if you aren't syncing Helix Rack from an external clock such as a DAW, Microcosm will still Clock sync with Helix Rack via Tap Tempo (controlled either on the HMI or on the Foot Controller) provided you have "MIDI" selected on the "Send MIDI Clock" setting. While you are in Global Settings you will want to make a crucial change. This was the biggest bottleneck I was running into when setting up MIDI to behave in the way I intended it too. Helix Rack has a default set of Program Change messages that it sends upon preset selection and in order to defeat this default you will want to set "MIDI PC Send" to "Off" (on page two of "MIDI/Tempo" settings if memory serves). Doing this will allow you to customize; within Command Center, which Program Change messages you want to send without interference from Helix Rack's default PC messages. Big Ups to forum user rd2rk for cluing me into this setting here: https://line6.com/support/topic/52777-helix-program-change-midi-out/ Command Center Settings: The other behavior I wanted to effect was selecting which of 44 presets Microcosm loads when I load different presets in Helix Rack. Hologram Electronics conveniently includes a list of Control Change and Program Change messages in Microcosm's user manual. To change presets we will be interested in Program Change (PC) messages which you will find on page 21 of Microcosm's .pdf manual or on page 40 of the physical manual. We will use Helix Command Center to assign which PC messages we want to send upon Preset or Snapshot Selection. On Helix Rack; from the preset you wish to assign MIDI messages to, navigate Menu > Command Center. This will bring up a display of Lightning Bolts, footswitches, knobs and expression pedals. Select one of the Lightning Bolts as this will be your "Instant" location. From here change "Command" to "Bank/Program" and on "Program" select the numerical value you want Helix to send to Microcosm. My experience is that Helix Rack sends PC messages starting at the value of Zero while Microcosm receives commands starting at a value of One, so you will want to send a value from Helix that is one subtracted from the PC value listed in Microcosm's manual. For instance, if you wished for the Microcosm preset, "Mosaic C" to load when selecting a Helix preset you'll have to assign a preset value of 22 even though the manual lists 23 as the program change value for "Mosaic C". Essentially you are fooling Microcosm into thinking that Zero is One, One is Two, so on and so forth. I discovered this on this HX Effects user's Youtube Video here. The user goes over it at around the 2:12 Mark. https://www.youtube.com/watch?v=LUZN5hl8QPo&t=202s My experience is that you have to change these values in Command Center for each of your Snapshots as well although there may be a way of not having to do this (in other words the Helix preset selects the Microcosm preset that's consistent for each Snapshot automatically) that I have yet to uncover. The utility of this is using Snapshots to select different Microcosm presets within a Helix preset. Make sure to Save your presets frequently. I find it helpful to save after every little change I make. Bonus points for figuring out how to assign CC messages to control certain parameters on Microcosm such as "Mix" and "Activity" via Expression Pedals. You can assign CC and PC commands to control Microcosm's parameters to the Foot Controller's footswitches within Command Center but this hasn't proved useful to me just yet. This process is way more straight forward and has been covered ad nauseam on YouTube, at least with other MIDI capable devices. This is by no means exhaustive, I just wish this information was a little more easily searchable for Microcosm specific questions. No doubt this can apply to other MIDI Capable pedals and devices. Learning how to program and use Helix Rack as a MIDI controller in addition to controlling Helix Rack with external MIDI is a total game changer for me. Hopefully someone out there finds this scratching at the surface useful.
- 1 reply
- 1
- helix rack
- hologram electronics
(and 4 more)
Tagged with:
I downgraded to Firmware 2.92 and it appears to have alleviated the issue.
Gave the factory reset a try and the issue persists
Having an issue with my HX Effects. Firmware is 3.01. When I press and the FS1 and FS4 and go into bank mode I notice that it auto scrolls through all the different presets. Is this normal? Is there a setting that is off? Is it possible to turn off bank mode all together? I find myself mainly using Preset and Snapshot mode and it would be nice to just be able to toggle between the two. I uploaded the following video to youtube to demonstrate the problem I'm encountering. https://www.youtube.com/watch?v=So_R4fei3y0
