BlueViolince Posted November 15, 2014 Share Posted November 15, 2014 Does anyone know what the exp-2 value defaults to when the expression pedal is removed? Is it the last known value, or min/max? Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 17, 2014 Share Posted November 17, 2014 Unplugging the second expression pedal doesn't really remove EXP-2. It just makes it so it's controlled by the onboard expression pedal. Clicking the toe-switch toggles makes the pedal toggle between EXP-1 and EXP-2. So if you go to a preset where EXP-2 was assigned to control a parameter (or multiple parameters), the value of those parameters will be whatever they were when you saved the preset. If you toggle the expression pedal to go to EXP-2, then you'll start changing the parameters. Quote Link to comment Share on other sites More sharing options...
BlueViolince Posted November 17, 2014 Author Share Posted November 17, 2014 Oh, okay. Second question: when I use the toe switch to go back to exp-1, is the exp-2 value going to be the max value? I assume so, but just want to make sure. Quote Link to comment Share on other sites More sharing options...
musical1212 Posted January 17, 2015 Share Posted January 17, 2015 I have also wondered the same thing. If I am using the on board pedal for wah and volume, when I depress the volume pedal (EXP1) to go to the wah (EXP2), will the volume go all the way up? If so, this would make a good case for always using a separate expression pedal. Quote Link to comment Share on other sites More sharing options...
