a1terrier Posted December 7, 2014 Share Posted December 7, 2014 Hi All Just rediscovering my Spider Jam and saw on the Line 6 website that the Aux In should be used for things like pedals and Pods etc. What is the difference between guitar input and aux input? Does the Aux bypass anything? Quote Link to comment Share on other sites More sharing options...
rarellano Posted December 7, 2014 Share Posted December 7, 2014 Hi, a1terrier I've tried to "clean" the Guitar input and it is impossible. Always your sound will be affected by a model amp, modeling or something. That is the reason because you must to use the Aux input if you want to hear the real sound of your guitar using an external pedal. I've read some opinions about and CD/MP3 input would be better to input these devices. Regards. Quote Link to comment Share on other sites More sharing options...
radatats Posted December 7, 2014 Share Posted December 7, 2014 You need to download the Pilot's Guide and the Advanced Guide to read up on how this all works. Basically the AUX input can be assigned to either the Guitar Amp and FX settings OR the Mic FX settings. If you want to use your POD through the AUX, you should assign the AUX to the Mic settings and then flatten the EQ and turn off the delay and compressor. Now you will have a clean POD signal without any Spider coloration. http://line6.com/support/manuals/spiderjam You could also send your POD Phones output into the Spider Jam CD/MP3 input and avoid all internal Spider AMPs and FX. If you want to use an MP3, plug it into your POD. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted December 7, 2014 Share Posted December 7, 2014 I've noticed that when assigning the guitar input to be recorded with the spider jams recorder the aux input's effects & tone stack are disabled. Like radatats said, read the manual when you get chance to freshen up on it's controls. Routing a Pods output to the cd/mp3 port on the pod sounds good, although I've run it into the guitar input using the clean green model, turning off all effects with the tone stack straight up and recorded with good results as well as the aux with good results. Depends on what your looking for. Quote Link to comment Share on other sites More sharing options...
a1terrier Posted December 7, 2014 Author Share Posted December 7, 2014 Thanks for replies-much appreciated Like what I hear using the mp3 input plus I can have my amp further away from me and tweak the Pod at the side of me Quote Link to comment Share on other sites More sharing options...
flipotto Posted March 29, 2015 Share Posted March 29, 2015 Thanks for replies-much appreciated Like what I hear using the mp3 input plus I can have my amp further away from me and tweak the Pod at the side of me +1 Quote Link to comment Share on other sites More sharing options...
a1terrier Posted March 29, 2015 Author Share Posted March 29, 2015 Is there a difference in signal level when using phone to mp3? Thanks Quote Link to comment Share on other sites More sharing options...
Brazzy Posted March 29, 2015 Share Posted March 29, 2015 Is there a difference in signal level when using phone to mp3? Thanks Whenever this question pops up I always turn the levels down and work my up to avoid a potential blown speaker or ear drum, lol. I would trun the CD input level down, turn the phone all the way up and make my setting (CD input level) with the master at where you usually keep it. Quote Link to comment Share on other sites More sharing options...
a1terrier Posted March 29, 2015 Author Share Posted March 29, 2015 Ok thanks for reply. Got most levels at 6 or 7 including master on SJam and guitar volume and its plenty loud enough for home use. Presume by using this method and by passing the amp its the same as going into a PA system. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted March 29, 2015 Share Posted March 29, 2015 Ok thanks for reply. Got most levels at 6 or 7 including master on SJam and guitar volume and its plenty loud enough for home use. Presume by using this method and by passing the amp its the same as going into a PA system. Yep, I would say it's like a PA function too. I like Spider Jam and use it all the time. Also, it's the most reliable 75w SS amp I've owned so far. I think a PA can handle a wider range of frequencies, but this amp sounds pretty good all around to me. Quote Link to comment Share on other sites More sharing options...
a1terrier Posted March 29, 2015 Author Share Posted March 29, 2015 Thanks for reply Brazzy Good info Started playing an open mic/jam session recently and one of the guys uses a pocket pod express and Telecaster straight into a Bose PA system and it sounds awesome. Says it saves him lugging a heavy amp about!! Is it the same signal using the phone out to mp3 as it is using output on Pod to front of amp? Quote Link to comment Share on other sites More sharing options...
