trueNorth55 Posted January 16, 2015 Share Posted January 16, 2015 Hi Everyone, I have a Mission EP1-L6 connected as the external expression pedal with my Shortboard Mkii (connected to POD HD Pro X) and it was working well for a while. Just recently, I noticed that my EXP-2 pedal won't reach 100% volume when fully engaged. I've tried resetting the volume pedal in my signal chain and reselecting EXP-2 as the control for the volume pedal, but it continues to only hit 93% max, or sometimes 77% for some reason. When I switch the function back to EXP-1 as the controller it works as expected. Does anyone have any suggestions? My next step is to flash the firmware on the HD Pro X. Quote Link to comment Share on other sites More sharing options...
BillBee Posted January 16, 2015 Share Posted January 16, 2015 If you have access to a spare expression pedal I would test that with the MKII just to see what's what. I don't like to reflash unless I have too. I don't have a Mission EP1 but if there is a pot inside those can wear in spots (brushes?). -B Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 17, 2015 Share Posted January 17, 2015 Have you tried a different cable between the expression pedal and the FBV? Quote Link to comment Share on other sites More sharing options...
trueNorth55 Posted January 18, 2015 Author Share Posted January 18, 2015 Unfortunately, I don't have another expression pedal to connect to test. I have also tested another cable, but still the same problem. There doesn't seem to be a way to calibrate the EX-2, only the built-in EX-1. Thanks for the suggestions so far; hopefully I'll figure it tonight. Quote Link to comment Share on other sites More sharing options...
trueNorth55 Posted January 19, 2015 Author Share Posted January 19, 2015 Reset fixed it. When I transferred all my presets back to the unit, everything was working fine again. Thanks for everyone's input. Quote Link to comment Share on other sites More sharing options...
