ChuckNorrik Posted February 27, 2015 Share Posted February 27, 2015 hi i bought a used fbv shortborad to control my hd147 and they sent me the board with a connecting cable witch look like an ethernet cable , but when i pluged it in the amp and the fbv only the '' a , b , c , d ''( the bottom line of button ) was working so i tried one of my computer's cable and now the upper line of button and the bottom line are working but not the middle line .....take note that when it start the light of the middle line is not working either....... so my question is do i need a specific cable ?? i've look on line6.com and i know that i need a cat5 cable .....i have like 6-7 cable at home and some make the first series of button working and others make the upper and lower series !?!? is my board broken or i need to buy a cable at my music store ??? thanks for your time and sorry for my English ...am french speaking from canada :) Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted February 27, 2015 Share Posted February 27, 2015 You want a straight Cat5 cable, not a reversing one. Check the pin contacts on the FBV and the HS - its very easy for them to get bent. Quote Link to comment Share on other sites More sharing options...
hughgrection Posted July 6, 2015 Share Posted July 6, 2015 I have an FBV Shortboard Mark II which I want to run into a Randall RM4 preamp/RT2 power amp. Since the FBV uses a straight cat 5 cable with one of those ethernet type plugs, it would require attaching a 7 point din plug to one end. From the Randall, din plug pins 3 and 7 carry the phantom power which is 9v ac 1amp. What wires in the cat 5 cable go where in the din plug? On a more general question, does anyone know whether the FBV will effectively communicate with the Randall? Quote Link to comment Share on other sites More sharing options...
stevekc Posted July 17, 2015 Share Posted July 17, 2015 We have an enforced non smoking policy - don't try it Quote Link to comment Share on other sites More sharing options...
