M13 distorted tape delay
andyman1974
I am getting distortion running clean on some of my scenes.   Some scenes were fine..   I tracked it down to tape delay.  Running straight through no other pedals..  The other delays are clean but tape delay is muddy and overdriven.
Edit:  My Volume pedal is boosting the signal causing it to overdrive.  Is this normal for a tape delay?
What's up?
Well, the Tape Echo is by design a more lo-fi delay. Have you tried the "Dry Thru" version? The regular version of that model affects the dry signal, and that may be what you're hearing. The Dry Thru version gives a you a clean dry signal.
