or8ital Posted April 1, 2015 Share Posted April 1, 2015 I was interested in possibly purchasing a G70 or G75. I have a guitar with two outputs. One for the standard pickups and one for the piezo. Each needs to go to a different destination. Can I go this with two transmitters and one receiver or do I need two receivers as well? Thanks. Quote Link to comment Share on other sites More sharing options...
eklynx Posted April 1, 2015 Share Posted April 1, 2015 You need two receivers as well, as each receiver can only pick up one signal, though two G55 receivers side by side will fit in one 1U rack space. Quote Link to comment Share on other sites More sharing options...
or8ital Posted April 1, 2015 Author Share Posted April 1, 2015 Thank you for clarifying. Quote Link to comment Share on other sites More sharing options...
eklynx Posted April 1, 2015 Share Posted April 1, 2015 Note: This is assuming you want both sounds heard at the same time. if you just want one or the other, then you can turn transmitter A off then turn transmitter B on and vice versa. Quote Link to comment Share on other sites More sharing options...
sdevino Posted April 2, 2015 Share Posted April 2, 2015 If you just want one or the other with the G70 or G75 you could use 2 transmitters keeping both on and switch between them using a single receiver. Program a scene for one and another for the other then step on the switch to go between them. Quote Link to comment Share on other sites More sharing options...
rleipsig Posted May 20, 2015 Share Posted May 20, 2015 I use three guitars on stage all with dual (magnetic & piezo) outputs that must work at the same time. Does Line 6 make anything that will run in this environment. Hard to believe there are not more artists out there looking for the same thing. The cost of 6 transmitters and receivers is way out of the scope of possibility. Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted May 20, 2015 Share Posted May 20, 2015 For this you would actually need 6 transmitters and 2 receivers. Quote Link to comment Share on other sites More sharing options...
