Stratotron Posted April 7, 2015 Share Posted April 7, 2015 How do I disable the Wah in the FX100? It is a little on the hair trigger side. It is OK on a patch where I use the Wah, but I have had it engage at improper times, for instance if I am a little off balance while operating the volume pedal. I believe I can insert a different effect there, but I then run the risk of toggling it on at the wrong time. For instance, is tere a toe switch assignmnet that I am missing? Thanks All. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 7, 2015 Share Posted April 7, 2015 Unfortunately there is no option to disable it at this time. It would be nice if you could set the min and max like you can on the volume pedal, so if you do accidentally engage it you could have it in a locked position. Quote Link to comment Share on other sites More sharing options...
