jjhcw Posted April 8, 2015 Share Posted April 8, 2015 UPDATE dead usb hub was my problem J 1 Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted April 9, 2015 Share Posted April 9, 2015 Thanks for the heads up jj. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted April 9, 2015 Share Posted April 9, 2015 What happens when you reinstall the driver? 1 Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 9, 2015 Share Posted April 9, 2015 thanks Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 9, 2015 Share Posted April 9, 2015 Just being an IT guy by trade i had to check for myself. I was able to update and tested the following things as working without any effort: hd pro x hd500 jtv59 jtv69 pod farm hd500 edit hdprox edit monkey workbench hd all the latest versions. my system late 2012 mac mini (yosemite) not denying the original posters issues... just saying mileage may vary, and things worked fine for me post update. 1 Quote Link to comment Share on other sites More sharing options...
leesteel Posted April 9, 2015 Share Posted April 9, 2015 Just being an IT guy by trade i had to check for myself. I was able to update and tested the following things as working without any effort: hd pro x hd500 jtv59 jtv69 pod farm hd500 edit hdprox edit monkey workbench hd all the latest versions. my system late 2012 mac mini (yosemite) not denying the original posters issues... just saying mileage may vary, and things worked fine for me post update. AWESOME! Thanks Zap! Quote Link to comment Share on other sites More sharing options...
trueNorth55 Posted April 9, 2015 Share Posted April 9, 2015 My POD HD PRO X is working fine with OS X 10.10.3 also. Like Digital_Igloo suggested, try reinstalling the driver. Quote Link to comment Share on other sites More sharing options...
GazzaBloom Posted April 9, 2015 Share Posted April 9, 2015 Works fine here with POD HD500X, Mid 2010 iMac, no re-install of driver required. Quote Link to comment Share on other sites More sharing options...
jjhcw Posted April 9, 2015 Author Share Posted April 9, 2015 Just being an IT guy by trade i had to check for myself. I was able to update and tested the following things as working without any effort: hd pro x hd500 jtv59 jtv69 pod farm hd500 edit hdprox edit monkey workbench hd all the latest versions. my system late 2012 mac mini (yosemite) not denying the original posters issues... just saying mileage may vary, and things worked fine for me post update DEAD USB HUB WAS MY PROBLEM. COINCIDENCE when i installed 10.10.3 what a headache. Quote Link to comment Share on other sites More sharing options...
Jamesdt Posted April 9, 2015 Share Posted April 9, 2015 Just did the update, on my Pod HD Pro, and now its just restarting itself over and over. Usb is not recognized. What do i do now!? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 9, 2015 Share Posted April 9, 2015 your computer is restarting or the pod is restarting? step one.. disconnect the two isolate the problem and report back. Quote Link to comment Share on other sites More sharing options...
Jamesdt Posted April 9, 2015 Share Posted April 9, 2015 The line 6 is restarting itself, not the PC. I disconnected the Pod HD Pro from the pc, started it and same thing hapend. It shows the menu, and after a few seconds its restarting itself over and over. I tried the factory reset but the screen just showed me "Update Flash". If i click the flash update i get the "80007211 error. Firmware update timed out waiting for response from the device." I even switched the usb entrance from my pc. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 9, 2015 Share Posted April 9, 2015 ok, so your computer is fine.... but the pod is stuck on the update flash screen? try powering the pod on while holding the direction key left. if there is no change try the same thing holding right. if it still comes up to the update flash screen, plug it back into the computer and attempt to run monkey again.... if monkey gives you an error unplug reboot machine... then plug into a different usb port and try again. Quote Link to comment Share on other sites More sharing options...
Jamesdt Posted April 9, 2015 Share Posted April 9, 2015 I have been doing all of that in the last 2h :( For 30min now, every time i start the line6, with or without the left/right/down arrow pressed, i just get a Update Flash screen. The Line6 Monkey can no see the unit, but i get an the same error every time i try to update. P.S. sorry for my bad engurish, im really tired of all this... :( Quote Link to comment Share on other sites More sharing options...
Jamesdt Posted April 9, 2015 Share Posted April 9, 2015 Good news! I started the unit using the left arrow key pushed down, and the flash update worked, but only after selecting all my other patches to be erased. It seems that this is the only way it worked. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 9, 2015 Share Posted April 9, 2015 that is good news, perhaps one of your patches got corrupted in the update somehow or had bad info in it if it was a download from an older firmware or such.... anyway good to hear you're back up and running. Quote Link to comment Share on other sites More sharing options...
Jamesdt Posted April 9, 2015 Share Posted April 9, 2015 Thanks for your help. I`m really glad i got everything working again! :) Quote Link to comment Share on other sites More sharing options...
RioBautista Posted June 20, 2015 Share Posted June 20, 2015 I haven't used my Pod HD500 on my MBP for a time. When I plugged it in now, it's not being detected. I realized I've upgraded my OSX to Yosemite already since the last time I used it with my Pod. Now, since the Line6 Monkey is already outdated, I decided to delete it and uninstall the drivers. I then downloaded the latest version of the Monkey (1.70). Monkey shows I don't have any driver installed and 7.3.8 is available. I updated the driver using the update selection button, laptop restarts as part of the installation and my Pod is still undetectable. I checked Monkey again and found the driver is still missing. I did several attempts installing the drivers, even downloaded the drivers and installing outside of Monkey and it still won't install. Also tried installing 7.3.7, and still no luck. So I guess my problem (for now) is how to get the Line6 drivers installed on my OSX Yosemite 10.10.3. Quote Link to comment Share on other sites More sharing options...
RioBautista Posted June 21, 2015 Share Posted June 21, 2015 OK, Got mine finally working... I had to use a PC to update the USB Firmware and Flash Memory to the latest versions. Then when I connected back to my Mac OSX Yosemite everything was back to normal. Quote Link to comment Share on other sites More sharing options...
