Adjusting amp dep with latest updates and dual amps
duncann
Thought I'd let people know the only functioning way I have found to know the values of the amp DEPs while using dual amps and the latest version of HD Edit, 2.26, while not messing with the pod itself, so as not to create sync errors.
1. Select, with the mouse, one of the cab DEPs.
2. Use the keyboard up or down arrow once, then the opposite of what you just did.
3. Select the amp DEP tab.
4. Select the amp DEP you want to adjust and adjust it using either the keyboard or mouse.
5. To see the value, you have to look at the pod's screen. HD Edit no longer displays this value.
6. To adjust more amp DEPs from the same amp you just adjusted, repeat steps 4 and 5,
7. To adjust amp DEPs from the different amp, repeat steps 1-5.
This is incredibly annoying to say the least. Apparently Line 6 is aware of this problem. Only question is how long till a fix.
 Hi Duncann,
I tried this myself (POD HD PRO edit 2.26.0, Firmware version 2.26, Windows 7) and everything works over here as expected. I can simply use the mouse to select and adjust the CAB dep's. I also can see the values displayed correctly in HD edit. No idea what could be going, maybe others can varify this as well so we get a better understanding of what is happening.
To make sure we are talking about the same issue: I'v uploaded a small video where I change the CAP DEP with my mouse...
Nope, you can't see the values. All you can see is a bar, not the percentages.. like the rest of us.
 Hi Duncann,
Now i'm wishing I had the rack model, not floor. :lol:
I don't know if they've changed it (I use Edit only to backup the previous bundle) but, I always wondered why there's often, if not always, a +1% difference in the values seen by Edit. For example if you set "Bass" to 10% on the hardware, 9 times out 10 you see 11% on Edit...
As Giorgos said, can't see the values.
The reason for the steps I've outlined for dual amps is if you adjust for one amp and then go to adjust for the other amp, you can't see the values, even on the unit itself, without first adjusting one of the cab DEPs on the amp for which you want to adjust an amp DEP..
I've been noticing this also lately, specifically on cab decay. But previous versions, prior to at least 2.26, seemed fine.
