royswan Posted May 15, 2015 Share Posted May 15, 2015 Can I use the Mk II Express to access all 25 banks in the Amplifi TT? or do I need the bigger FBV? 1 Quote Link to comment Share on other sites More sharing options...
KuRiXY Posted May 28, 2015 Share Posted May 28, 2015 I only have FBV, and it works for bank switching very good. Quote Link to comment Share on other sites More sharing options...
godoyrafa Posted December 19, 2015 Share Posted December 19, 2015 Same question here... Any answers? Quote Link to comment Share on other sites More sharing options...
AndyParedesMusic Posted December 26, 2015 Share Posted December 26, 2015 If you are planning to use the FBV (only) to access all the banks you will need the short board, which gives you bank up/down footswitches. If you are using the FBV in conjunction with your smart device you should be able to select the "bank" on the device, then access the A-D presets from the FBV controller - in this case the Express will be fine Quote Link to comment Share on other sites More sharing options...
